Stage 2 AFR
Old May 17, 2009 | 01:34 PM
krazycobalt's Avatar
Stage 2 AFR
Hey, anyone running a stage 2 tune and 42,s with a 3" pulley, what is your AFR at WOT?
Old May 17, 2009 | 01:37 PM
Darkmanx's Avatar
10.5-11.2
Old May 17, 2009 | 03:08 PM
coopn8r's Avatar
Rich and safe.
Old May 17, 2009 | 05:18 PM
Hockeyman's Avatar
It should start out at low 11's/high 10's and at redline be low/mid 10's.
Old May 17, 2009 | 06:23 PM
rico's Avatar
lmao thats the afr im getting with my ottp stage one now it went from 11.6s to 10.8s and 11.0s now but oh well better safe than sorry i guess
Old May 17, 2009 | 06:24 PM
SlowBalt_06's Avatar
lmao..it was a cooler night ..wot in third gear....9.9-10.3 lmao thanks gm
Old May 17, 2009 | 06:29 PM
Hockeyman's Avatar
gotta love GM, I was in the low 10's as well all through the powerband.
Old May 17, 2009 | 06:53 PM
Yeh haha get this...
1st gear WOT - 10.0
2nd gear WOT - 10.0
3rd gear WOT - 10.4
4th gear WOT (lower RPM's) 10.5
Old May 17, 2009 | 06:56 PM
Hockeyman's Avatar
read by an AEM wideband? It's prob lower than 10, since that's the lowest reading it puts out. Mine was the same way in some gears. At least it's safe, right?
Old May 17, 2009 | 06:58 PM
Ohh yeh it is nice to know that everything is running safe and that there is still a nice tune possible for my car. Yes it is being read off of a AFR pod
Old May 17, 2009 | 11:59 PM
jeanbalt's Avatar
http://www.hptuners.com/forum/showth...air+fuel+ratio
good thread about a/f sensors
Old May 18, 2009 | 12:46 AM
coopn8r's Avatar
Its safer than running lean, but running that rich isn't necessarily what you'd call.. Good , lol.
Old May 18, 2009 | 12:48 AM
Frew's Avatar
10 flat or a 9.8 if im lucky, rich ftl
Old May 18, 2009 | 09:31 PM
Thats nice to know thanks guys.
Old May 18, 2009 | 09:57 PM
GPZRider96's Avatar
dang... i'm pulling high 11's up to about a 12.4 in 2nd/3rd... no knock though so whatever
Old May 18, 2009 | 10:24 PM
Hockeyman's Avatar
12.4 is a bit lean, probably won't hurt anything but you will get the most power from a 11.7 or so ratio.
Old May 18, 2009 | 11:37 PM
Zach06CobaltSC's Avatar
Do you have any proof backing that statement up out of curiosity?
Frew's Avatar
--x2
Old May 18, 2009 | 11:39 PM
12.4 is lean, but I would like to see some dyno charts showing that 11.7 makes the most power.
Old May 18, 2009 | 11:40 PM
Hockeyman's Avatar
A reputable tuner stated it a while back, I believe he said the most torque came from a 11.6 ratio and the most hp came from a 11.8 ratio. I don't know what to search for, but i'll try to find it.
Old May 18, 2009 | 11:42 PM
If you could find that I would like to see if there was any proof/results backing it up or if it was just another random claim someone made lol.
Old May 18, 2009 | 11:46 PM
Hockeyman's Avatar
i'm curious too...i'm trying to find it but no luck so far.
Old May 18, 2009 | 11:48 PM
Well after the new tranny and clutch and axles and mounts and all that jazz is broken in I will put her back on the dyno and get some real dyno proof. See if at the same timing what afr the car likes the most . I will also be spraying the 50shot for the first time woot woot. Should be looking at around 330whp.
Old May 19, 2009 | 10:56 AM
Bika's Avatar
Fail Less.
are you running meth injection? if not, 12.4 is too lean for a 2.8 pulley
how much timing are you running?
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
