Stage 2 belt install
I have searched & searched and have found nothing about this. There's no write up on it either. I just ordered the belt and was looking for some info on the install. Like what all needs to be done to put the new belt on? level of difficulty? any tips and tricks anyone would like to pass on?
ok here you go:
before you take the old one off remove the passenger front tire.
pull the splash gaurd in the wheel well back.
note how the belt is routed around the pulleys
once you have that done, take a 15mm wrench and behind the tensioner pulley there is a 15mm notch thing where you put the open side of the wrench on
push down and to the rear at the same time, should compress the tensioner
remove belt from the pullies
route new belt like the old one was.
this belt is going to be shorter. so i am assuming that you have a smaller pulley on the s/c.
ok here you go:
Ha thats funny but no. I have all the necessary performance parts just putting them all on at one time.
