Stage 2 with CA 2.79 pulley
Old Aug 17, 2007 | 05:06 PM
MRyanSc/SS's Avatar
Just wondering if anyone is running this set up on their car and how they like it? How safe is it to run? I plan to get along with that GMPP header, ZZP drop pipe and GMPP Performance cat-back system. And wondering about what kind to hp i can expect if anyone knows?
Old Aug 17, 2007 | 05:14 PM
Shortbus's Avatar
If using a 2.79, i would just go ahead and get 60s, and a custom hp tune, because with stage 2 tune, anmd injectors the idc will most likely be maxed, or you could fine a really good tuner who knows alot about idc could re tune it for you and hopefu;;y mot have the injectors maxed.
Old Aug 17, 2007 | 05:17 PM
light'bolt's Avatar
what shortbus sez, oh and don't forget the extra heat you'll get, might want to cool that off.
edit: exhaust too something about backpressure
Old Aug 17, 2007 | 07:24 PM
MRyanSc/SS's Avatar
I live in Minnesota. Does any one know a good place to get a tune at.
Old Aug 17, 2007 | 07:36 PM
SS_SC_Cobalt's Avatar
keep in mind that if you have a good flowing header and exhaust you will lose some boost pressure...which should help you out.
max pressure on a 3" with header and exhaust and stage tune is 14.5psi...not a big boost over the stock 3.31...
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
