Stage 2 Ecu
Old Jan 25, 2008 | 08:26 AM
DVSk8er's Avatar
Stage 2 Ecu
Alright well this is what happened. I got a 06 ss/sc ecu with the stage 2 gm tune on it but totaled the car. My question is can i use that ecu in my new 07 and just throw in some stage 2 injectors or 42lb injectors and change out the pulley.
Old Jan 25, 2008 | 03:26 PM
saunders1986's Avatar
no.......... for one thing the 07 ss/sc has a completely different ecu than the 06's
Old Jan 25, 2008 | 03:36 PM
DVSk8er's Avatar
alright thanks man. thats what i wasnt sure about
Old Jan 25, 2008 | 03:37 PM
splitimage's Avatar
yes he can u goofball
hed be swapping out the ecu, so unless there is something about the wiring up im not aware off it should be fine
i know 05 06 are interchanable anyways.
Old Jan 25, 2008 | 03:44 PM
the 07 is a COMPLETELY DIFFERENT ECU ALONG WITH THE WIRING......... THEY ARE NOT INTERCHANGEABLE, also........ the stage 2 tune for the 07's are different than the stage 2 tune for the 05-06's
Old Jan 25, 2008 | 03:45 PM
DVSk8er's Avatar
alright well does anyone else know for sure. casue thats all i'm trying to do is swap the ecu completely. i know i have to have it relearned and all that but i just wanna know if its gonna work so i dont have to buy a whole nother stage 2
Old Feb 7, 2008 | 04:43 PM
DVSk8er's Avatar
bump i am still trying to find out if they can be swapped
Old Feb 7, 2008 | 04:47 PM
fballman1987's Avatar
they cant be swapped, he's right 07's need a different tune and have different computers.
Old Feb 7, 2008 | 04:52 PM
ive told u already.
Originally Posted by saunders1986
ive told u already.
i agreed, but then you get the not so smart person, that tells you a lie and it ruins it
Old Feb 7, 2008 | 06:15 PM
srowler9's Avatar
I don't know about the wiring, but the stage 2 reflash is the same for the 07s as the 05-06
Old Feb 7, 2008 | 06:19 PM
thedubsack85's Avatar
you are oh so wrong.. if the ECU and the tune is the same why did i have to wait 3 month's to get the proper tune for my 07 IRL? cause i had to wait for GM to release the damn tune cause it wasnt the same. and the first day they released it i had it on my car. september of LAST YEAR.. trust me on this. i had the first 07 stage 2 LSJ.
Old Feb 7, 2008 | 06:20 PM
chevysalesman614's Avatar
you could swap an 05 for an 06, but my understanding is that the 07 pcm is slightly different, as well as the tune for the 07 stage 2 kit.
plus there are other factors to account for, like, does the old car have on star? does the new one?
does the old car have side impact air bags? does the new one? etc. etc.
i would just sell the 06 computer and use the money towards the stage 2 kit for your new car.
Old Feb 7, 2008 | 06:52 PM
forget it, i tried to help........... install ur 06 pcm, and watch ur **** go BLAMO! make sure u take a video
Old Feb 7, 2008 | 07:02 PM
lnf08ecotec's Avatar
wow, this turned to an arguement fast, listen to saunders.....there's a reason..you have to order an 05-06 kit...or an 07 kit...reflash is different tune bc fuel map if different on 07's....wiring isn't different that I know of, except your 07' might have different features on the pcm than your 06' which might cause certain things in your car to not function...or not function right.........oh yeah, and you also can't reflash an 06 pcm with an 07 reprogram....tried it at work before (flashing an 06' vehicle with a reprogram that I accidently set up for an 07') won't work.....
...but if your q is simply to put the 06 stage 2 flashed pcm into your 07 with the stage 2 injectors and pulley, etc...it won't work bc the pcm won't communicate with the newer 07' modules.....
Last edited by lnf08ecotec; Feb 7, 2008 at 07:02 PM. Reason: Automerged Doublepost
Psykostevo's Avatar
The data changes are the same, but the bitrate on the 05-06 ecu is 16bit and the bitrate is 32bit on the 07. To me that would say incompatible.
Old Feb 7, 2008 | 10:23 PM
DVSk8er's Avatar
alright thanks thats all i was trying to find out. not saying i was gonna do it unless i knew for sure that it would work. well since thats the case does anyone want an 06 ecu
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
