Stage 2 help
I have a 2006 cobalt ss/sc.. I currently have a injen c.a.i and magnaflow exhaust making about 14 and half to 15 lbs of boost.. I want to go to stage 2 but im not sure what i need or where to to get it tuned. Can someone help me with what i need to do or where i could get a tune perferably a dyno tune??
If you're getting a Stage 2, OTTP, GM Stage 2, & ZZP all offer tunes or a new PCM with their stage kits. All tuned (usually not always) correctly for the parts you're putting in.
Some times minimal tuning is required after wards.
You need to research all of the available stage 2 options (GM, ZZP, OTTP, CA, etc.), and decide which suits your goals best.
I bought the car off a buddy of mine and he had put the magnaflow exhaust on it but he took the high flow cat off and put the stock cat back on, so would that be making the boost higher?
there are no "chips" for the ss/sc.
Thats what i told him, ive looked many times and never found anything.. but i really do want to stage 2 my car, whats the best setup??
im still new with superchargers and im not sure what all to do to make sure it dont blow on me.. for example, whats a core charge on zzp? is tht the ecu
its there was bolts it would mean u would have aftermarket smaller pulley or stage 2 pulley so if ur stock. Your stock downpipe is probably clogged which is why ur seeing such high psi.
ZZP Downpipe. Just added the 3 inch catless to mine. Definately worth the money plus it bolts up to a stock system. Not sure what you are but ZZP has my vote.
Look on your pulley for any numbers as well like 79 or 76mm. Numbers like 2.6 to 2.9 might be on it as well. And your pulley is what controls your boost.
3inch intake,42's, nates 2.9, s3 h/E, vibrant header and exhaust and a zzp pcm tune till you find a tuner to fine tune it. To me thats a true stage 2 anything else and you just wish you woulda saved your money.
which stage 2 are you refering to? gm stage 2 or ottp/zzp stage 2? If you plan on going stage 2 as in 2.8/60 injectors, i suggest a heat exchanger from zzp or ottp AND a meth injection kit. The meth kit is amazing when it comes to the cobalt. Like the pulley and injectors, the meth will require a tune, i highly recommend a dyno tune for that.
