Stage 2 hub FRUSTRATION!
Old Aug 9, 2008 | 12:37 AM
smurfy79's Avatar
Ok, is it just me, or is it extremely hard to remove the GM stage 2 hub??!! I have 2 different pullers, however they are not budging the hub. Has anyone else had troubnle removing the hub or any sugestions on which puller/installer to use? Any help is greatly appreciated!
Old Aug 9, 2008 | 12:46 AM
camarokiller's Avatar
Just have nate make you a pully to fit the stg 2 hub, then you dont have to mess around with it.
Old Aug 9, 2008 | 12:47 AM
scampbell's Avatar
Originally Posted by camarokiller
Just have nate make you a pully to fit the stg 2 nub, then you dont have to mess around with it.
what he said.
Old Aug 9, 2008 | 03:55 AM
theneelster's Avatar
To each their own...
I think intense, cobalt addiction, nate (smoothflow), and a couple others are selling removers but I can't recommend either one. I'm guessing you want to go lower than 2.7. They all should work but it might take some time and/or pb blasters to get it off.
Old Aug 9, 2008 | 05:01 AM
I thought nate could do down to a 2.6 for the GM hub?
Old Aug 9, 2008 | 05:27 AM
raptors_67's Avatar
I've gotten the stage 2 hub off with my puller no problems....
Old Aug 9, 2008 | 03:06 PM
smurfy79's Avatar
Which Puller did you use?
Old Aug 9, 2008 | 03:14 PM
ls1fbody's Avatar
Haz l33t wheelz.
i've heard people haet it up and it slips right off. not 100% on how hot it has to get
Old Aug 9, 2008 | 03:17 PM
chris88z24's Avatar
Use heat and Nates puller, should come off but it doesn't come off easy.
Old Aug 9, 2008 | 07:30 PM
smurfy79's Avatar
I'll try it again, I used a bit of heat but it wouldn't even budge a mm! If That doesn't work I'll try Nates puller and worst case I may cut it off!!
Old Aug 9, 2008 | 09:37 PM
nherbst454's Avatar
I would be happy to make a puller for you! Just let me know.
Nate
Old Aug 10, 2008 | 09:16 PM
raptors_67's Avatar
ZZP's puller. I put my hub on late at night (bad idea when you're half awake) and right after I put it on I realized it was on backwards. I bolted the stage 2 pulley on to the hub and used the puller to pull the whole thing off and then put it back on the right way.
Old Aug 11, 2008 | 02:01 AM
I don't think there's enough clearance for it but you should ask him.
HEATON
Oct 16, 2015 07:21 PM
Sep 30, 2015 07:22 AM
cw383
Sep 30, 2015 12:41 AM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
