stage 2 install ?
^^ Good call. Contacted the dealer i bought my 05 from and they quoted the install at $276 and 2.5 to 3 hours... I'm gonna try it on the dealer that's down the street from me and see if they can beat that quote...
With the right tools, it shouldn't take over 2.5 hours...20 mins for the injectors, reflash the PCM while you work on the SC pulley, and the belt can be quickly swapped while the blower is off...
I need tools.
I need tools.
Ask me
i did the install myself with my dad.
You will need a pulley puller which i borrowed from patathSS.
took us about 3 hours with a bit of screw around time at sears. we made a few minor mistakes which made it take longer but none of the mistakes took more than a few seconds to fix.
the supercharger does have to come off. the gasket does NOT need to be replaced.
what i did about the reflash was before hand set it up with my dealership to have them do the reflash for me after the install.
i just babied it to the dealership and let them do their thing.
any questions feel free to PM me.
Originally Posted by snarkee
they used the pully puller and it bent the lip of the stock pully....it was on there soooo dam tight that they had to use the press machine
the range should be about 240-280 for the total job at a parts installer. The issue is the call they need to make to verify the vic number. that call can take an hour by itself so just make sure they do it WHILE installing the part otherwise be prepared to pay more for nothing
no it should about about 240 labor 2 1/2 hour job. I got a deal on my labor cus the service manager hooked me up but 240 is what it shoulda been
1.5 hours for injectors
1.5 hours for pulley
1 hour for reflash
1 hour in there for something i can't remember (new plugs???), but anyways he said the total was...
5 hours @ $88/hour = ~440
He said the normal shop price was actually 118/hour. Why he would give me that discount when the work is only about 440, I don't know. Where the hell are these 2.5 hour install shops??? I'm still planing on installing myself and just paying for the reflash, but goddamn $440 sounds ridiculous.
Originally Posted by Mike06cobalt
Just talked to my dealer and here's what he says for labor...
1 hour for reflash
1 hour for reflash
Yeah dude. I've got chevy dealers up the wazoo around here so I'll call around to figure this out. I just wish I could get a clear answer on if me installing and them only reflashing it will void a warranty or something. Stealership is right...
My bad about the S/C coming off, I forgot I was on the dreaded cobalt forum when I posted lol, I usually flip back and forth. However my Redline was factory designed for quick pulley changes! Saturn was thinking performance first! (HA).
1 hour for reflash
1 hour for reflash
One of the dealers I checked with looked in the book and came up with 3.7 hours total.
1.5 injectors
1.5 blower
0.7 reflash.
I went elsewhere.
I say do it yourself. Just buy that pulley puller/installer from intense, it worked great for me. My brother and I did the install in about 4 hours (we took our sweet time!). The hardest part was trying to slip in the belt and relieving the tensioner to slip in the belt.
GM Stage 2
GMPP Exhaust
Ingals TQ Brace
K&N Intake
GM Stage 2
GMPP Exhaust
Ingals TQ Brace
K&N Intake
1.5 injectors
1.5 blower
0.7 reflash.
I went elsewhere.
1.5 injectors
1.5 blower
0.7 reflash.
I went elsewhere.
install
well i paid one of the techs under the table to do the flash.
I was getting the door handles replaced so i just slipped him $40 to do the flash while i put the door things in.
i would say what ever the hourly rate is would be fair.
no more than 1 hour.
So I attempted to install the stage2 this weekend. Got the injectors in fine and went to pull the pulley off to no avail. Guess I need a heavy press. I can figure out how to get the pulley off easy enough, but how do I get the pulley back on without applying force to the supercharger casing which the directions expicitly tell you not to do (probably cause it will mush the aluminum). Help?! I'm figuring I have to use a press to pull it back on using the thread in the shaft, but who can do that? No GM dealers have the equipment around here.
YES you must remove blower! you don't need to take it in the house or anything but you must unbolt it to get it maneuverable.
Don't be afraid to remove blower. Just take a before pic, and make sure everything goes back in place.
Your best bet is to pony up the cash at GM, you get a 3 year warranty and no greasy fingers.
