Stage 2 Problem?
Old Jun 19, 2011 | 11:22 PM
Sully20's Avatar
Stage 2 Problem?
Hey Guys,
I just recieved/Installed my GM Stage 2 in my 2007 Cobaly SS, Now everthing went well, However, I had read that the Rev Limiter should have been Extended to 7,000 RPM and when I got the car back it STILL said that Redline was ar 6,500? Is this Normal? Thanks
P.S. Is it also Normal to get like 24-26 Miles per Gallon? Seems like Since I put the GM Stage 2 in it Decreased my Gas Mileage by about -2 to -3 per Gallon?
Old Jun 20, 2011 | 02:27 AM
PenguinPIE's Avatar
did you try redlining it and see if the rev limiter is set to 7k?
the stage kit may reduce your fuel economy a bit but i was told the on board mpg reading is not accurate anymore due to bigger injectors used
Old Jun 20, 2011 | 12:04 PM
Sully20's Avatar
I Just thougt that when the Kit gets Installed that you would Visibly see the Higher Rev Limit. Is that Not the Case? Thanks
Old Jun 20, 2011 | 12:25 PM
Staged07SS's Avatar
Administrator
Administrator
Not when using the GM 42lb/hr injectors. The fuel economy reading will be just as accurate as it was stock. When you enter the world of aftermarket/larger injectors they tend to skew the reading.
As for the 6,500rpm limiter issue. GM reduced the limiter back to 6,500rpm in some of the later issues of the tune. I would still take it back to the dealer and ask them to make sure they did in fact flash your PCM though.
Old Jun 20, 2011 | 12:55 PM
BlueTurbo's Avatar
Visibly? As in, on the tachometer when you redline it? Or just all the time?
Old Jun 20, 2011 | 02:59 PM
Tstonee's Avatar
Were you expecting them to take an eraser and erase some of your redline so you could VISIBLY see your redline was 7k?
Old Jun 20, 2011 | 03:19 PM
mrbelvedere's Avatar
lmao
Old Jun 20, 2011 | 03:48 PM
PenguinPIE's Avatar
no they will not swap out your tachometer
Old Jun 21, 2011 | 11:22 AM
Sully20's Avatar
Wow Tstonee, I am picking up on your Sarcasim...Smart Ass, Look....I am New to all of this and I NEVER worked on cars before let alone did any MODS or anything like that, I just wasent sure if they were supposed to install a new Tach(one that goes to 7,000) or if indeed nothing changes?
Old Jun 21, 2011 | 11:37 AM
Sully20's Avatar
As for the 6,500rpm limiter issue. GM reduced the limiter back to 6,500rpm in some of the later issues of the tune. I would still take it back to the dealer and ask them to make sure they did in fact flash you PCM though.
Hey "Helix", Where abouts are you from in Pennsylvania? If you dont mind me asking. I'm just really New to all of this and I could really use a Friend who knows what the Hell their talkin about!
Old Jun 21, 2011 | 11:50 AM
Staged07SS's Avatar
Administrator
Administrator
I'm from the Scranton area.
If you need help feel free to PM me anytime. You will learn over time most of the guys are just busting your ***** on this site (don't get too bent out of shape). There are a lot of helpful members on here. Some days are better than others though, haha.
Old Jun 21, 2011 | 02:08 PM
if you need help sully just hollar you little pimpster
Old Jun 21, 2011 | 06:39 PM
Sully20's Avatar
Thanks Guys...I Appreciate ALL of your Help! Tell you what though, I have Noticed a Huge Difference between my Balt just having a CAI(Air Box MOD) and having GM Stage 2 Installed as well, Its like Night & Day! The Boost Builds much Faster, Harder and Longer. Next MOD: Exhaust, Header/Down Pipe Combo.
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
