Stage 2 / question
Old Feb 1, 2013 | 03:50 PM
07balt_ss_sc's Avatar
Stage 2 / question
Hey guys, so im currently running an 07 sc balt with a bad mab header, 3 inch hahn catted dp and a 3 inch zzp catback, and also an injen cai. I am getting a little bored with the power its making at the moment and am looking at staging it, basically i want to know what would be the most reliable setup with decent gains that ill have fun with, i need reliable because i do construction and drive 100-130 miles a day. I'm looking at the zzp stage 2 kit, but am leery on what pulley size and if ill be okay without cooling mods and such, any input would be awesome thanks guys! -Jeremy
Old Feb 1, 2013 | 03:58 PM
YelCal7's Avatar
You really don't need 3" exhaust unless if You go beyond 300hp. But You already got 3" Exhaust that lose alittle horsepower on the top end. I am on 3" ZZP Catted with 2.5 exit with 2.5 ZZP Exhaust. I have 50# on 2.8 pulley with all the cooling mods from ZZP for faster recovery time. I have ZZP 3" CAI most guys here had Injen gone to ZZP. My car has been pulling n pulling LIKE HELL! Just go with ZZP Stage 3, Get Custom Tune after that. You will have a HUGE SMILE ON YOUR FACE!
Old Feb 1, 2013 | 05:22 PM
574's Avatar
574
Don't waste money on a stage kit, your paying for the convience. Shop the for sale section and go with 2.9 50/60 injectors and a stage two belt. Cooling mods on a 2.9... meh not needed unless you want to.
Old Feb 1, 2013 | 06:23 PM
YelCal7's Avatar
I am on 2.8 n when I go WOT. My tuner showed my IAT2 don't go above 135 degrees at 85 degrees outside that time I got my car tuned during the summer. I will be porting my Supercharger to get better degrees.
Old Feb 1, 2013 | 08:20 PM
ThexGovenor's Avatar
I wouldnt go below a 2.8 pulley.
Old Feb 1, 2013 | 09:29 PM
okay, so 2.9 is the smallest im probably gonna go, and yah man I realize about the 3" i plan on going tvs and what not when i can pick myself up a nice DD, thats why i planned ahead.. but thanks for the input guys helps alot!
Old Feb 1, 2013 | 09:32 PM
If you have 93 or better fuel, snag a 2.8 Its the best of both worlds. It doesnt overspin the blower too hard and create a ton of heat, but it gives quite a bit of torque.
Old Feb 1, 2013 | 09:41 PM
YelCal7's Avatar
It does give better torque at the Top End. It's AMAZING! My Eyes POPPED!
Old Feb 1, 2013 | 09:43 PM
05RLS2's Avatar
Most reliable and decent power gains, GM Stage 2 without a doubt
Old Feb 1, 2013 | 09:45 PM
Here is what your list should consist of, trust me on this:
2.8 pulley
60# injectors if on 93 (80# if you want E85, if its available do that)
dual pass
option B
Front mount Heat exchanger or Griffin
3" intake. There are a few companies that make them (zzp, ottp and others)
The exhaust you have should be fine.
Interceptor gauge to watch for knock and other stuff (its worth the 250 bucks)
Hit the gym so you are strong enough to control the torque steer in 2nd!
And obviously a custom tune!
Old Feb 1, 2013 | 09:52 PM
YelCal7's Avatar
50# is Good too, Easier to Tune.
Old Feb 1, 2013 | 09:55 PM
very true yelcal. I would hope he can go E85 though always a better option. But if he wants to eventually go TVS he will need at least 60's thats why I suggested them :wink:
Old Feb 2, 2013 | 02:19 AM
Vander Nars's Avatar
2.7 80s e85 <--- this is what u want op jk
U should be good with 2.9pulley 50s/60s injector and bigger tensioner pulley. Consider some cooling mods tho for the summer, either dual pass or a upgraded h/e.
Old Feb 2, 2013 | 03:30 AM
KillaCam1353's Avatar
same setup i was gonna do, just need to buy the rest of the parts and find a tuner. I'm nervous to see how quick my car will be after this.
Old Feb 2, 2013 | 11:38 PM
Cory05SS's Avatar
do you need to run a header/downpipe for a stage 3 kit? I was looking at going with ZZP's stage 3 kit, but I only have a catback & intake, so I wasn't sure if I would need to purchase headers and a downpipe to make sure it would run correctly. Also will be doing a custom tune on 93 octane
Old Feb 2, 2013 | 11:40 PM
BankerBalt's Avatar
you're going to see a lot more power with a more free flowing exhaust. less back pressure = less boost, but = more power
Old Feb 2, 2013 | 11:49 PM
Ok, the 3" exhaust isnt bad, but its better suite to the TVS. It will lose power on the M62.
Old Feb 2, 2013 | 11:50 PM
Cory05SS's Avatar
very true. I was told from a local tuner that if I went with the stage 3 kit and didn't have a header/downpipe that I would burn up my internals...I think it would be fine without them myself, I just wouldn't get the most potential out of it.
Old Feb 2, 2013 | 11:59 PM
what exhaust do you have?
Old Feb 3, 2013 | 12:05 AM
Cory05SS's Avatar
Borla Cat back & Injen Cai intake
Old Feb 3, 2013 | 12:17 AM
any header?
Old Feb 3, 2013 | 12:23 AM
Cory05SS's Avatar
any header?
nope stock header. I wanna get the ZZP stage 3 kit, but wasn't sure if a header & downpipe is a must need to go that route. If it is, I will go with the ZZP header/downpipe set-up. My plan is to go with that stage 3 kit(2.8 pulley) and then get a custom tune.
Old Feb 3, 2013 | 12:25 AM
Header is a really good option. not necessary... but you should get it.
Old Feb 3, 2013 | 12:26 AM
Cory05SS's Avatar
Thank god tax returns are right around the corner lol
Old Feb 3, 2013 | 12:28 AM
I mean its up to you, but the header will make the best power....
