Stage 2 with smaller pullies..
Old May 1, 2007 | 07:54 PM
ItalianJoe1's Avatar
Originally Posted by Area47
then again, these are autometer boost gauges. you would get a more accurate reading if you stuck your ass in a bucket of water and farted.
True, but I dont really care at all what a guage tells me i'm boosting. As long as the car is running hard, im good.
Old May 1, 2007 | 08:59 PM
burntorange's Avatar
i see 17 with the 2.79"
Old May 1, 2007 | 09:01 PM
M-Dub's Avatar
17.5-18 with S2 with 2.85"
Old May 1, 2007 | 09:47 PM
Mikey851's Avatar
Originally Posted by ItalianJoe1
Well, thats what the gauge said. I couldn't give a ****, boost pressure is ******* worthless anyway. I could have 60 psi, it just means that the air is not going into the engine.
When its 90+ outside, with the same humidity, and the car is 210+ coolant temps, in third I bet I was seeing 18-19 psi. This is Miami
True. It does however pack alot of mass (not necessarily dense air) into the cylinder; this is why cooling mods work so well. Even though our engine doesn't utilize alot of the boost in stock form flow wise we can at least pack the coolest air possible into the cylinder.
If I had alot of money I would concentrate alot on flow mods including properly matched cams.
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
