Stage 2 Supporting Mods
Old Sep 8, 2010 | 11:20 PM
babyCobaltss's Avatar
Question Stage 2 Supporting Mods
If i go with the OTTP Stage 2 kit with the 2.8 pulley and the 60lb injectors, what other mods will i need i have a DC Sports CIA intake right now. what else am i looking at needing? Header/dp and keep stock cat? or get an exhaust system and header?
Old Sep 8, 2010 | 11:44 PM
mrbelvedere's Avatar
there is a stage 2 search button u could use
Old Sep 8, 2010 | 11:50 PM
07superchargedcobalt's Avatar
i just put the stage 2 on and i just through a code p0171 . i sprayed carb cleaner around all vacuum and injectors and the supercharger ideal didn't change. is it the 02 sensor ? let know if any one knows
just dont want to hurt my car you know
Last edited by 07superchargedcobalt; Sep 8, 2010 at 11:50 PM. Reason: Automerged Doublepost
Old Sep 9, 2010 | 02:21 AM
insylem's Avatar
P0171 = System too Lean
Check your fuel trims, I bet they are ABOVE
20
A tune should help, but check for vacume leaks first.
Old Sep 10, 2010 | 03:51 AM
06SS ALL DAY's Avatar
zzp s3 all day
Old Sep 10, 2010 | 01:12 PM
blewis13's Avatar
I would at least get a downpipe with a 2.8, header can wait but you'll see more power with one obviously.. Probably want some cooling mods
Old Sep 10, 2010 | 02:54 PM
Bluelightning's Avatar
Got Bewst?
First thing should be cooling mods IMO
Old Sep 10, 2010 | 03:13 PM
coopercharge's Avatar
zzp stage 3 h/e, dual or single pass intake mani, possibly methanol injection.
Old Sep 10, 2010 | 03:44 PM
b00sted06ss's Avatar
that would be a good start
Old Sep 10, 2010 | 03:50 PM
scotch89's Avatar
cooling mods asap! get a aeroforce scan gauge to moniter IAT2
Old Sep 11, 2010 | 02:01 PM
Thanks guys i just ordered Vibrant Header/DP and will probably order the ZZP S3 Heat exchanger?
Old Sep 11, 2010 | 04:00 PM
ziggity's Avatar
Do you know anyone close by with hptuners? If so deff get a tune.
DarrenGC
Dec 24, 2021 01:55 PM
bigdeertz
Nov 17, 2016 09:41 AM
HEATON
Oct 16, 2015 07:21 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
