Stage 3 with nitrous dyno
Old Jan 14, 2007 | 12:05 PM
zinner's Avatar
Moderator Alumni
Ok, I don't have the GM stage 3 however, I have basically the same setup.
The mods:
2.8 Pulley
42# injectors
HPtuners (soft tune)
50 shot of nitrous 3500-6800 RPMS
All 3rd gear:
1st pull no nitrous
2nd pull 50 shot
3rd pull 50 shot (better pressure and purged, hence the 290 ft lbs of tq)
Old Jan 14, 2007 | 12:07 PM
DaREDss's Avatar
very nice man
Old Jan 14, 2007 | 12:09 PM
zinner's Avatar
Moderator Alumni
I should mention this is a warm car and I had no knock.
Old Jan 14, 2007 | 12:14 PM
Ljavy17's Avatar
wow, good numbers, with the 75 shot, youll be over 300whp. 300;bs of tq is insane!!!
Old Jan 14, 2007 | 12:20 PM
zinner's Avatar
Moderator Alumni
Yeah they started the sample a little high, the nitrous kicks in at 3500 RPM
Old Jan 14, 2007 | 12:32 PM
Matty's Avatar
Good numbers.
Old Jan 14, 2007 | 12:36 PM
CobaltBurst's Avatar
same company i dynoed with, nice number zinner. I still havent had enough cash to get my new clutch etc =/, did you tune yours or did they?
and by warm car, did you mean tuned for warm weather?
Old Jan 14, 2007 | 12:41 PM
zinner's Avatar
Moderator Alumni
I tuned mine, and they car was warm, the tune is a year round tune ...
DTM2188's Avatar
Very nice numbers
Old Jan 14, 2007 | 12:44 PM
ooo gotcha, is just above 10 AFR good for our cars? looks like you were about 10.5/6 on ur last pull
Old Jan 14, 2007 | 12:45 PM
GeoChevyCobalt's Avatar
Vary nice numbers. I can not wate till out get that thing to the track. What is your injector duty cycle. You can probly drop it with the wet kit but with your first run I would like to know because with 2.8 and 42s people have been saying that the injectors are maxed out????? I know it is on a car by car basis but I would like to know how yours is holding up....
Old Jan 14, 2007 | 12:50 PM
it also looks like the drop in ur AFR lowered your tq until it went back up at 6200
Old Jan 14, 2007 | 12:56 PM
zinner's Avatar
Moderator Alumni
Injector duty cycle is 112% @ 7000 rpms ....
about 19ms according to HPT
Old Jan 14, 2007 | 01:28 PM
woooo sounds like you need the 60lbs. How about the GB from TAG??? We are getting really close to the 3 teir>>> Any way just a little nudge but like I said you should be OK when you hit the Wet kit but just be safe...
How does it feel on the road. Give us the play by play up to 100.
Better yet show us a video.. Closed course and alll and make sure it is on dry pavment I know the wether is bad all over the US so be carfull.
Last edited by GeoChevyCobalt; Jan 14, 2007 at 01:28 PM. Reason: Automerged Doublepost
Old Jan 14, 2007 | 01:31 PM
distillion's Avatar
awesome #s!
Old Jan 14, 2007 | 02:13 PM
BlackSS/SC's Avatar
Nice numbers! Isn't it kinda lean though?
Old Jan 14, 2007 | 05:46 PM
an0malous's Avatar
very nice!
Old Jan 14, 2007 | 06:03 PM
blackphoenix's Avatar
nice numbers zinner.. i got the same mods as you.. what kind of tune did you do.. was it just for the nitrous? do i need a tune if i'm gonna do a small 35 shot with a zex dry kit? what would you suggest?
Old Jan 14, 2007 | 06:23 PM
Boost Fr33k's Avatar
wow 112% that cant be too healthy for the car.
Old Jan 14, 2007 | 07:14 PM
JAESS's Avatar
nice #'s. I've been wanting to put nitrous on my balt. I think a nice little 50sot would be nice. Thanks for the post.
Joe
Old Jan 14, 2007 | 08:22 PM
zinner's Avatar
Moderator Alumni
I wouldn't do a dry kit without bigger injectors.
I have the stage 2 tune with stock timing for nitrous.
Old Jan 14, 2007 | 09:31 PM
LandonElf's Avatar
You setup is kind of in the neighborhood of stage 3, but remember the GM pulley is actually a 2.99.
Also, remember the GM kit has 100 octane capabilities. So what i want to see is a GM Stage 3 Cobalt with GM header and GM exhaust doing a dyno run with a tank full of 100 octane and a 50 shot.
My money is that 300 would be easily obtainable with this setup. And it would be as reliable as can be.
Well now i'm just rambling, but great numbers man!
Old Jan 14, 2007 | 10:13 PM
zinner's Avatar
Moderator Alumni
A header is on my list of things to pick up, it's just a matter of what header at this point.
Also I plan on doing a 75 shot with some 100 octane fuel.
My tune is also very conservative , my AFR could be a bit higher (12.25-12.5) and I could of done a 75 shot with my timing.
Old Jan 14, 2007 | 10:18 PM
mattyfinch's Avatar
112% duty isnt terrible, they wont fail till 120% but id get the 60's
and with some exhuast work, that car would open up like a can of tuna!
Old Jan 14, 2007 | 10:41 PM
2K5SS/SC?'s Avatar
Nice numbers man. I'm jealous. I definitely need more power...
