Stage 3 pulley with a stage 2 kit?
Old Nov 1, 2007 | 10:51 PM
Mr McCabe's Avatar
Question Stage 3 pulley with a stage 2 kit?
Can someone please tell me if a stage 3 pulley will work with my stage 2 kit? Does this pose any kind of risk to my engine? What COULD go wrong? Also, what would the change in boost and hp be ( I believe the st. 2 is 245hp with 15.5psi)
I did a search for this but couldn't find what I was looking for.
Thanks!
Old Nov 1, 2007 | 10:56 PM
Hockeyman's Avatar
i have the stage 3 pulley on, no problems, it's only 3 inches.
Old Nov 1, 2007 | 10:59 PM
nherbst454's Avatar
Why go stage 3 when you can go with a 2.9 or 2.85?
Nate
Old Nov 1, 2007 | 11:00 PM
jgarciarivera's Avatar
Works perfectly, not much of a difference
Stg 2 pulley = 3.06"
Stg 3 pulley = 2.99"
Old Nov 1, 2007 | 11:19 PM
XM15's Avatar
Go with Nates 2.9.
Old Nov 1, 2007 | 11:24 PM
FryLoch's Avatar
I've got the Stage 3 pulley in the mail. Can't wait to put it on.
Edit: what would the psi be on a stage 3 pulley? Im at just over sea level. like is it 16?
Old Nov 1, 2007 | 11:31 PM
tREBs's Avatar
Nate
i have nates 2.9 pulley with stg 2 and it works very well
had it for about 4 months now trouble free!
very good quality work as well got the puley for $65 shipped
Old Nov 1, 2007 | 11:34 PM
95cam86roc's Avatar
I have nates 2.9 and its the way to go on the Stg 2. My 2.9 is on a custom tune and love it!!!
Old Nov 1, 2007 | 11:35 PM
ssaddiction's Avatar
nates 2.9 is the way to go adds alot from the stage 2 pulley wont have any problems will bump you from 15 to 16.5 and will put you in the correct tune because the stage 2 is rich
Old Nov 1, 2007 | 11:52 PM
tREBs's Avatar
mine still runs rich
but as soon as the balt come out from hibernation im tuning her!
Old Nov 2, 2007 | 12:29 AM
nherbst454's Avatar
Just so other people know, it was 65.00 because it was shipped to Canada.
Old Nov 2, 2007 | 01:27 AM
tREBs's Avatar
o ya i definatley shouldda added that! even still best $65 ive ever spent!....car wise that is!
Old Nov 2, 2007 | 03:02 AM
snobrdrdan's Avatar
I'm getting the Stage 2 kit & thinking about getting Nate's 2.9" pulley....
Do you "have to" run colder plugs with the Stage tune & a 2.9" pulley???
Old Nov 2, 2007 | 04:10 AM
2.0freakotec's Avatar
yes i would put colder plugs in i have step 2 colder plugs and they are good i feel anything under 3" pulley size u should get different plugs i got mine from zzp
Old Nov 2, 2007 | 04:30 AM
Super_SS's Avatar
i got 2.9 and im boostin 23psi...
danm forgot i have a clogged cat and my motor will blow if i dont fix it
Old Nov 4, 2007 | 08:26 PM
Cdub901's Avatar
Is there a How-To for putting on nates 2.9 pulley cause I couldnt find one and I would like to see or at least have it explained how to do it?
Old Nov 4, 2007 | 09:09 PM
nherbst454's Avatar
It's actually quite easy...
1. Loosen bolts holding stage 2 pulley on
2. Loosen belt using 15mm open end wrench on tensioner
3. Remove belt from supercharger pulley
4. Remove bolts and stage 2 pulley
5. Put new pulley on stage 2 hub and start/snug bolts
6. Put belt back on supercharger pulley
7. Tighten bolts
8. Enjoy added boost!
Hope this helps!
Nate
Old Nov 4, 2007 | 09:31 PM
Code5's Avatar
Step 3.5 Use Craftsman strapwrench on pulley to break bolts free. ( they used red locktite on mine).
Old Nov 5, 2007 | 02:23 AM
snobrdrdan's Avatar
I sort of get what you're trying to say.......but how is a strap wrench gonna break the bolts free though???
Old Nov 5, 2007 | 05:11 AM
rukkee's Avatar
It holds the pulley so it doesnt slip . Sometimes when they have locktite on them , the bolts will be so hard to get off that the pulley will spin even when the serpentine belt has full tension on it . Thats where the strap wrench will be a life saver.
Old Nov 5, 2007 | 05:17 AM
snobrdrdan's Avatar
OHHHHH now I get it & it makes sense.....to hold the pulley when you're undoing the bolts!!!!
duh
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
