stage kit need some opinions
zzp/ottp/gm ???? I have been trying to research to find out what the best stage kit is to go with, but I cant decide on one so I thought I would get some opinions...I would like a kit I can put in myself and not have to go anywhere to get a re-flash or tune, just bolt it all on and go type thing... I want to start pushing some HP...So shoot me some ideas...
u cant just bolt on a stage kit and go, it has to be tuned. A stage kit comes with fuel injectors and when you upgrade the injectors you have to change the tune. Especially if u get any of the kits from those vendors, they come with 60lb injectors and when i was at my mechanics shop to get tuned we wanted to see what the car would do when we just put in the injectors, had a hard time starting up, started and then stalled in 5secs or so
If you still want to get the kit then go with OTTP
If you want hp increase without getting a tune then get header, downpipe, full catback exhaust system and a cold air intake
you can bolt on ottp kit they send you a pre tuned pcm? BUT, it isnt a perfect tune. you can still bolt it on and go. It would run fine. Stage two from gm is like 1100 if you let them do it for you+tune
well if you go with one of those zzp or ottp kits it comes with the pcm right? or I send mine in and they have it back within a week I heard? so If i did that when I got the pcm back I could just put the kit and pcm on and go right?
I was thinking of getting the stage 2 gm kit and I have a spec 2+ clutch get that installed at the same time but I bet they would rape me on the stage 2 and the labor for everything.........
ZZP comes with a 3" pulley and 39lb injectors.. Why those injectors, I'm not sure..
You'll be happy with any of the kits, I'd go with OTT, thats just me.
OTTP's setup is probably the best one out there. If my car hadn't come with a GM stage 2 on it when I bought it, I would have gone with OTTP. I'll get around to getting it one of these days.
Sep 28, 2015 12:51 PM
