Stage Kits
Old May 22, 2006 | 12:42 PM
SSpartan's Avatar
Stage Kits
everybody who has satge 1 or 2 GM kits what is your redline and how much boost are you seeing i just got mine in and im a little bit scared of the new power so i havent maxed it out yet.
thanks
Old May 22, 2006 | 12:54 PM
OniMirage's Avatar
dont be scurred
Old May 22, 2006 | 12:59 PM
CTCOBALTSSS's Avatar
I have stage 2, I get 15 pounds of boost and my redline is 7,000rpm's. Look at my sig and you'll see my stage 2 dyno. That should help. Notice the 7,000rpm range.
Old May 22, 2006 | 01:35 PM
Asstyme's Avatar
I have stage 2 and I'm getting 15 pounds of boost and my redline is 7,000 rpm's.
Don't be scared, it's not a rocket ship. Just hang on to the wheel
Old May 22, 2006 | 03:52 PM
SSpartan's Avatar
huh
i wasnt asking for people opinions i wanted boost levels and redlines.
thats all.
the warranty issue for you is obviously dead as you work at a dealership!
and i dont understand the above quote are you bagging on me or him?
as i said i was impressed by the intense kits numbers but i decided to go with GMs kit. i never (gag) on the aftermarket.
can we please get back on the topic at hand
That is if you have a GM stage kit what is your redline and how much boost are you seeing?
thanks SSpartan
Old May 22, 2006 | 03:53 PM
OniMirage's Avatar
thats all.
thanks SSpartan
im with you bro
Old May 22, 2006 | 07:17 PM
Ghalterman_usmc's Avatar
redline on mine is 7000 and i get 15 pounds of boost....enough for me!!!!
Old May 24, 2006 | 01:06 PM
OniMirage's Avatar
just called the dealership, MINE CAME IN WOOOOOOOOOOOOOOOOOOOT hellz yah gonna get that bisch installed right after work I can't wait.
I will let you all know the redline and boost levels I see when it is installed
Old May 24, 2006 | 01:47 PM
CobaltSSilver's Avatar
7000 RPM redline and I see around 12-13 Pounds of boost but I am in the Mile High City. 5280 Ft. Elevation.
Have fun with it. I went with GMPP Stage 2 so I can keep warranty. The intense kits are tempting, but if I can get the cash and some mechanical help I'm going to try and duplicate what's going on in the gmperformance.com lsj build up to 300 HP.
I will be replacing my clutch, maybe the LSD upgrad to quaife otherwise just following the build book and I should be ok. If there are other weakpoints besides those I am pointing out here and that are in the build book PM me or post here as I will be getting notification on this thread.
Enjoy your kit!
Old May 24, 2006 | 02:51 PM
OniMirage's Avatar
Enjoy your kit!
I am following the same route and if there is still hp to be made after the upgrades I will look at the hp tuner software to optimize afr
Old May 24, 2006 | 03:08 PM
tivie85's Avatar
Dam i cant wait my stage 2 getting installed right now as i am typing i work at a gm dealership so i hope they hurry up i will post boost as soon as i can
Old May 24, 2006 | 03:22 PM
snarkee's Avatar
i'm sooo jealous....i want mine
Old May 24, 2006 | 05:13 PM
codyss's Avatar
With my only mods being Stage 2 and a K&N Drop-In (E-0777 the right one) I see 15 to 16psi after 6000rpm.
Old May 24, 2006 | 05:26 PM
Yeah I need to get the GMPP header and Corsa exhaust on to open up the other end a little more.
Old May 24, 2006 | 05:27 PM
Is there any data on just how much wheel HP and TQ gain can be had using the HP tuner in conjunction with the GM Reflash ect...?
Old May 24, 2006 | 05:30 PM
Tomtwtwtw's Avatar
I don't know about gains and such, but I believe there is no conjunction. You can only have one or the other.
Old May 24, 2006 | 05:42 PM
DTM2188's Avatar
With the Stage 2 kit I have 7k redline and my boost is about 15.5. Enjoy your kit!
Old May 24, 2006 | 06:49 PM
Maybe the better question is. What is the wheel HP and TQ using HP Tuners and the Injectors and 3" pulley from GM vs. same hardware and the GM tuning? Also can you flash back and forth between the two like I can with my Hypertch for my Silverado?
Old May 24, 2006 | 07:24 PM
mattyfinch's Avatar
there really isnt much point to tune over the stage 2 with hp tuners if u arent adding more fuel(larger injectors) or a smaller pulley.
stage 2 is pretty much full out with u add in an exhaust and intake really..
SSpartan's Avatar
dyno
i will be dynoing my car on the 1st
i got my baseline from the same place so hopefully ill get similar conditions.
ill post results here.
i have no other performance mods other than stage 2 so we will have very accurate results.
i wanted to have every step documented.
my stock results were 206 hp 198 trq
Old May 24, 2006 | 07:29 PM
Tomtwtwtw's Avatar
Well the stage 1/2 flash from GM is just made specifically for the equipment that comes with it, while also meeting all emissions regulations, etc. With HP tuners, you have a lot of customization options available, and should be able to make more power with the same hardware, but with greater risk if you don't know what you're doing.
Also have no idea about the switching back and forth...but I imagine with HP tuners, you can revert all the settings you change fairly easily.
If I'm wrong there, someone please fix it for me.
Old May 24, 2006 | 09:03 PM
SSpartan's Avatar
HP tuners
i dont have HP but patathSS does and i saw him working with it and it appeared to me that if you have multiple saved programs you could easily falsh back and forth.
but like the above post mentioned if you dont know what your doing you could ruin your car.
there is no reason anybody would have both the GM stage kits and the HP tuner suite.
while having the GM program to build from would be smart most people just buy fuel trim management program from somebody else.
as far as comparison between the two
i couldnt tell ya yet.
Old May 24, 2006 | 11:24 PM
OniMirage's Avatar
many are getting gm stg 2 for the warrenty issue (by the way mine did not get installed today hopefully tomorrow but I have the parts ready).
If you use gm stage 2 until your cars warrenty is gone you can enjoy performance without much of a risk. Once you have other stuff squared away and the HP tuner software becomes more robust you will welcome the software for optimizations such as the afr. The gm reflash is just pre tested settings to allow the kit to run smooth for the specific application while meeting regulations.
Old May 24, 2006 | 11:32 PM
patathSS's Avatar
Let's go to the track John!!!! I want to see what this stage 2 does!!!
Old May 25, 2006 | 12:00 AM
SSpartan's Avatar
patathSS
dyno first boy!
i forgot i got good news. and bad news. check your pm.
