Stage Kits
Old May 25, 2006 | 01:32 AM
CobaltSSilver's Avatar
Originally Posted by SSpartan
i will be dynoing my car on the 1st
i got my baseline from the same place so hopefully ill get similar conditions.
ill post results here.
i have no other performance mods other than stage 2 so we will have very accurate results.
i wanted to have every step documented.
my stock results were 206 hp 198 trq
That is damn close to what I got stock. Let me know, I'm trying to get back to the dyno since all I currently have is GM stage 2 on it. I do plan on getting GMPP header and Corsa exhaust as the next performance upgrades, but will dyno before I add them.
Old May 25, 2006 | 01:38 AM
i dont have HP but patathSS does and i saw him working with it and it appeared to me that if you have multiple saved programs you could easily falsh back and forth.
but like the above post mentioned if you dont know what your doing you could ruin your car.
there is no reason anybody would have both the GM stage kits and the HP tuner suite.
while having the GM program to build from would be smart most people just buy fuel trim management program from somebody else.
as far as comparison between the two
i couldnt tell ya yet.
Yeah I looked it over and it seems like the HP Tuner is similar to the set-up on my Dad's motorcycle. I tuned it with someone else's tune that was out on the net. I backed up the 'factory' config to my computer and off loaded it to a usb flash card.
Yeah, for now maybe I'll just do the exhaust, intake, header for a little more power. Then concentrate on a few suspension tweaks, get better tires and a set of all-season performance tires since I am in Colorado then see where I am at in a few. I have an extended warranty and the whole idea when I bought the car over SRT-4 is to have the warranty on the stage kits, along with passing emmisions, street friendly ect.... I just get excited at the prospect of getting to a track and posting sub 13 second 1/4 mile times. (Don't worry I don't expect to get that in Denver's thin air, but I do expect if I did say intense stage 4 or 5 to get real close to breaking into the 13 second range at 5280 ft)
Thanks for all the info folks!
Old May 25, 2006 | 01:43 AM
Originally Posted by mattyfinch
there really isnt much point to tune over the stage 2 with hp tuners if u arent adding more fuel(larger injectors) or a smaller pulley.
stage 2 is pretty much full out with u add in an exhaust and intake really..
I agree that if were to go down in pulley size and add larger inectors then I could make better use of the HP tuner. I do believe however *based on some assumptions and working with other programmers for various vehicles* I could tune the Cobalt after having stage 2 done to get a little more power. The tradeoff may be emissions not being passed or causing damage to the vehicle.
Since my goals are more toward keeping warranty, more into street power than track power *for now * and passing emissions I will stick with what I've got and open up the airflow on the back-end and do some other upgrades to the ride. I may invest in the upgrades listsed on gmperformancedivision.com.......For all you intense guys keep us informed I may change my mind in the next few months.
Old May 25, 2006 | 07:09 AM
Badmunky's Avatar
I have stage 2 and I have a 7k red line and am geting 16psi out of it.
3,000 miles or so after geting stage put on it my clutch is slipping. Grrrrrrrrrrr
Its going to the dealer in less then a week to have them look at it.
Later
Old May 25, 2006 | 12:29 PM
dervin3's Avatar
7K redline and 16 lbs of boost. I plan on going to the dyno today to see my final numbers...
Old May 25, 2006 | 12:56 PM
SSpartan's Avatar
what i was thinking
see what i wanted to do was know exactly how much hp each mod is adding.
dervin3 you have everythin i want basically but i want each step documented ya know.
your mod list looks like my wish list!
ill get back on here after the 1st to post the results
Old May 25, 2006 | 01:03 PM
OniMirage's Avatar
i am just going to use the stock gm reference for my baseline then dyno when I start adding mods. stage 2 i will obviously dyno then when I do intake exhaust i will dyno the two together.
Old May 25, 2006 | 09:33 PM
OniMirage's Avatar
DAMNIT that thing pulls.
I am not exactly sure how much boost im getting but it is definently 15+. The redline on mine appears to be about ~7200 before it backs off the rev limiter but I am not sure cus you get there so fast I had to watch the road ( closed course ... of course). Right after the install the revs werent falling when I was in neutral they stayed at about 1400 then fell slowly but after a good warmup they sat steady at about 800. Oh and even after a couple nice runs flooring it (can be scary) I am still getting 24 MPG WOOOOOOOT.
Old May 26, 2006 | 01:18 AM
I've taken mine up to 7K RPM. I keep hearing it is 6750 but if it is then I've gone over. I haven't hit anything like the rev limited before.
I take it when you got on the track that it wasn't the same as the rev limited before.
What are the valve springs and the rest of the internals rated for RMP wise? I keep hearing different stories and I don't want to over do it with my car since I am actually loving it with the Stage 2.
Old May 26, 2006 | 02:33 AM
OniMirage's Avatar
im not sure but if the redline was raised and passed all regulations for safety from gm I am sure the internals are of a high enough quality to survive without issue.
I just remembered something. While I was taking bulldog for a spin a couple hours ago I noticed that when I switch gears at about the 7000 redline there is a soft yet easily noticable sound as if a had a mild bov. This interests me because I am for one wondering what it could be. All the parts were installed correctly by the tech dude at the dealer and I looked over the work to make sure everything looked as it should. Any ideas of what it could be?
ineedacobaltss
Nov 7, 2015 02:25 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
