Stage One
Old Dec 6, 2005 | 09:19 AM
djt81185's Avatar
Why does it talk about body kit moldings? Thats awesome if they are out tho.
Dan
Old Dec 6, 2005 | 09:34 AM
memphisr24's Avatar
Originally Posted by Alex47
memphisr24 when you get the stage one we have to run again stage1 SRT VS stage1 Cobalt SS/SC
Definately, but I think i'm going to go with stage 2 right away or stage 1 with injectorsand a 2.8, then a clutch upgrade
Old Dec 6, 2005 | 10:20 AM
hatrickstu's Avatar
cool about the parts, but im still gonna outrun you guys with just drag radials when i get em
Old Dec 6, 2005 | 10:26 AM
Dman's Avatar
anything?
Old Dec 6, 2005 | 10:34 AM
GeoChevyCobalt's Avatar
My life is filled with anticipation now.
Old Dec 6, 2005 | 10:40 AM
OniMirage's Avatar
hmm ... would be interesting if they are available ... hmm
Old Dec 6, 2005 | 10:44 AM
arsenal21's Avatar
I hope this is true Stage II will help me get through the snow better.....
Old Dec 6, 2005 | 10:45 AM
bdwarr6's Avatar
That came straight from the person that designs cobalt part's they are also coming out with factory body kits, if you dont belive me dont read my threads its that simple. I know where i get my information from and if you doubt me dont read my posts its realy simple.
Old Dec 6, 2005 | 10:48 AM
OniMirage's Avatar
False...
edit: they are part numbers but are listed as ground effects kits and each number is a different color ... future part not yet available
edit2: this came directly from the aftermarket parts dealer here in az ... the computer pulled up the numbers and image but the listing for the numbers are not what we are looking for
edit3: aftermarket parts dealer was from bill heard chevy
edit4: now im just wondering what these ground effects kits look like
Old Dec 6, 2005 | 10:49 AM
R33P3R007's Avatar
360 L337 User
no luck yet. still waiting for the call back. 10:49 am EST
Old Dec 6, 2005 | 10:53 AM
  #36
05BlackSS's Avatar
Also waiting for a call back still!
Old Dec 6, 2005 | 10:57 AM
  #37
jester's Avatar
Originally Posted by JCswoosher2
just switch it back when it tears up.
Dont they put paint or something over the bolts to see if they have been moved or not?
Old Dec 6, 2005 | 11:03 AM
  #38
italstalnprd86's Avatar
how can the pully for the stage 2 be a 3"????? if it really was, there would be a hell of a lot more than 241 hp...... I read somewhere that for every .1" you go down in size, you gain 1 psi of boost, and for every 1 psi it is roughly 10 hp. to me, since the stage one bumps it to like 230 or something, that would only mean they are like dropping it one size, from the 3.35 to a 3.25 or so. Someone correct me if I am wrong, but i think the 3 inch pully after the stage one especially should be good for more than 10 or 15 hp. The other thing, as far as prices, I will pay whatever for the stage one, but if the stage 2, which is supposedly just a new pully is rediculously overpriced, in comparison to the DUB unit, or any of the other aftermarket pullies, i would def. not buy it. I have a 3 inch pully already, and I plan to install it over X-mas break as I am at school......
Old Dec 6, 2005 | 11:10 AM
  #39
Darksun's Avatar
Well the psi thing can't be intirely tru cause you got to think about it this way our 2.0 on 1 psi with the m62 makes lets say 10 hp for that one psi a 2.8 tiburon with the same chager at 1 psi might make 12 cause of things like the size of the motor, compression things llike that. There is no clean cut rule on much hp you get from a certain amount of boost IMO.
Old Dec 6, 2005 | 11:13 AM
  #40
I realize that, however, i did say roughly....... the only way to tell would be to dyno it, and to hook up a different gauge that would read higher than 12.5, does the reflash allow us to hit and show above the 12.5?
Old Dec 6, 2005 | 11:16 AM
  #41
arsenal21's Avatar
The guage goes above 12.5 . My stock SS SC is pulling 14-15. That's with the stock guage.
edit: not toally stock. I've got a FUJITA code thrower on it too
Old Dec 6, 2005 | 11:27 AM
  #42
what did you do the bypass mod? I can't wait to hit above 12.5
Old Dec 6, 2005 | 11:48 AM
  #43
arsenal21's Avatar
I kinda got into a car accident. I think they did something with my ECU because the dealership had a hard time getting it to start. It definitley gets up there more quickly now.
Old Dec 6, 2005 | 11:53 AM
  #44
Darksun's Avatar
im hitting 17.5 to 18 on my guage in 4th gear
EDIT: with bypass mod
Old Dec 6, 2005 | 11:58 AM
  #45
Jmc007's Avatar
You definitly own a 2,85 " pulley with that kind of boost !
Old Dec 6, 2005 | 12:44 PM
  #46
bdwarr6's Avatar
Ok my bad in the email if you read it says about the ground effects she sent me part numbers to those, that means i dont have the numbers for stage 1 but she said it was released. I will get them tonight
Old Dec 6, 2005 | 12:55 PM
  #47
Jmc007's Avatar
Maybe your clutch is slipping too ...
Old Dec 6, 2005 | 12:58 PM
  #48
Darksun's Avatar
I though that but i felt what my clutch is like when its slipping it felt and sounded different. I use to down shift hard with out rev matching the car and the clutch went soft this slip fet different.
Old Dec 6, 2005 | 03:40 PM
  #49
AlphaJaguar5's Avatar
Noone has gotten a response back as to if these kits are ACTUALLY availible yet??
Old Dec 6, 2005 | 03:59 PM
  #50
Dman's Avatar
looks like it
