Stage one or Stage two??
Old May 17, 2007 | 11:23 PM
07 SS/SC's Avatar
I did a quick search and didnt find exactly what I was looking for so here we go. I was looking at the stage 2 kit but then got an Idea. I can get stage one plus the GMPP performance cat back installed for about the same price as the stage 2 kit installed. My first intentions were to get the stage 2, GMPP cat back, and a CAI. After looking at the numbers I could go with stage one plus the catback and see the same results as stage 2 alone, and spend the same if not a few $$ less. (Correct me if I am wrong). The final goal with this car is to see high 13's. Is that out of the question with Stage one, GMPP catback, CAI, and a few suspension mods to help with wheel hop?
Mike
Old May 17, 2007 | 11:25 PM
mrphoto103's Avatar
From: Voted by the people, most likely to get pulled over by a cop
go stg2, get tuned and tract mods. If your in IL go see Sp00ner, he can tune you. Best thing I ever did to my car. Tell him I said hello.
Old May 17, 2007 | 11:29 PM
cblt12's Avatar
i think stage one and a catback would be your best bet, but you will not get the torque that stage 2 provides... that brings me to my next point, you should put a smaller pulley on the stage one when your money allows and you would have the same thing as stage two or better depending on the pulley size you choose.
Old May 17, 2007 | 11:34 PM
07 SS/SC's Avatar
Any idea about where he is located in IL??
Mike
See I was thinking the same thing, but is the GM stage one tune capable of dealing with a smaller pulley? If I dont have anyone to tune for me (tweek the GM tune) am I SOL if I want to drop pulleys? If I were to go back in and say I want the stage 2 tune after I get the stage one, I would end up paying more $$ than if I had just went with stage 2.
Mike
Old May 17, 2007 | 11:35 PM
cblt12's Avatar
yes the gm stage tunes are the same for both stages... i have stage 1 and a 2.9 and it works great!
Old May 17, 2007 | 11:42 PM
07 SS/SC's Avatar
Now that is what I like to hear! So the only thing different about stage one and two is the addition of a smaller pulley? I am not doubting you but can anyone else varify that stage one and two tunes are the same?
Mike
Old May 17, 2007 | 11:45 PM
cblt12's Avatar
do a search... the only other difference is the smaller belt that you will also have to buy... its only like 35 bucks though.
Old May 18, 2007 | 12:57 AM
07 SS/SC's Avatar
If I get stage one, then buy the pulley and new SC belt, dont I need a new hub for the SC?? If so, can I buy that by alone?
Mike
Old May 18, 2007 | 01:03 AM
Dayn's Avatar
If you are getting custom tune you may as well just buy parts and screw the stage kit.
Pulley
belt
injectors - the expensive part but not bad at all.
tune
Old May 18, 2007 | 01:08 AM
07 SS/SC's Avatar
I doubt I will get a custom tune. Probally just stick with the GM one.
Mike
Old May 18, 2007 | 01:11 AM
an0malous's Avatar
Do you want warranty or not.
thats the important question.
Old May 18, 2007 | 01:19 AM
07 SS/SC's Avatar
Considering my car has 700 miles on it, YES I want the warrenty .
Mike
Old May 18, 2007 | 01:34 AM
ItalianJoe1's Avatar
Do what I did, get the stage 1, then buy your own belt and smaller pulley, 2.8-2.9 or so. Much cheaper than the stage 2 kit and you get the exact same thing. The tunes are identical.
Old May 18, 2007 | 01:46 AM
an0malous's Avatar
be aware that if you truely want no hassles with warranty, buying stage 1 and then going the cheaper route and pully'ing it yourself isnt the way to go.
Not that i dont think its a good way to do it....but if you truely want to keep your warranty...you should stick to GM parts, installed by GM.
this is all dependant on what your dealership is like....and a ton of other things.....
some people can get away with alot more aftermarket than others....
but stage 2 installed by GM is the warranty safe route.
Old May 18, 2007 | 09:11 AM
07 SS/SC's Avatar
Thanks guys! Is there any way to get just the stage 2 hub from GM? Or can I only get it by purchasing the stage 2 kit? Keeping my warrenty is a must and I will only use GM parts.
Mike
Old May 18, 2007 | 09:12 AM
Coblt ss super's Avatar
stage 1 and 2.9in pulley!!!
Old May 18, 2007 | 09:16 AM
thought's Avatar
GM hub only comes in Stage 2 kit. Aftermarket pulleys may come with their own hub......may not.
Old May 18, 2007 | 09:19 AM
SmOKe JeNsOn's Avatar
Mike
You have to have a GM tech install everything so that it is properly documented in their system. I say go with stage 2.
Old May 18, 2007 | 09:52 AM
07 SS/SC's Avatar
Well thanks everyone for the opinoins! I think I may just go with stage 2 so that I have an easier time with warrenty work if I need it. It will be worth spending the few extra dollars.
Mike
Old May 18, 2007 | 11:58 AM
Yea my plan is stage 2 than gm catback. I might buy dampner and springs 1st, just depends on the money situation tho.
Old May 18, 2007 | 01:14 PM
FryLoch's Avatar
I can recommend the stage 2 kit.
Old May 19, 2007 | 11:18 PM
05redline's Avatar
Stage 1 is a waste, stage 2 is definately worth it.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
