Standalone ECU options for LSJ?
Old Aug 14, 2008 | 01:01 AM
bolus's Avatar
Does anyone have any recommendations for a standalone complete replacement for the ECU in the LSJ?
FAST XFI seems to be one option, though not a drop in replacement. It looks like it is normally used with the ecotec distributor to replace the coil on plugs
http://www.fuelairspark.com/Products...s/xfi/over.asp
AEM has a controller that says it supports the cobalt but I cant find anyone who has done it
http://www.aempower.com/ViewCategory...CategoryID=116
Any other options to look into?
Old Aug 14, 2008 | 05:11 AM
burntorange's Avatar
Talking me too!
I am really interested in this and would like to see some answers.
Bump for an awesome thread
Old Aug 14, 2008 | 02:08 PM
bolus's Avatar
I spoke with AEM this morning. The only concern they had for their universal engine management system to work was the cam and crank signal. They have a solution for a 1 pulse per cycle cam signal and a 60-2 crank signal but anything else would require sending them a cam and crank signal trace to work out something custom.
It would also only run the engine of course. no door locks or other electronics but that's fine for me.
Anyone know on the cam and crank signals? A friend has borrowed my cobalt engine service manuals.
The AEM part number is #30-1900U universal
http://www.aempower.com/ViewCategory.aspx?CategoryID=63
Old Aug 14, 2008 | 02:37 PM
Witt's Avatar
LSJ crank is 60-2 (58x) with a mag sensor. LE5 is 60-2 with a hall effect just as an fyi.
AEM EMS will not control an electronic throttle, you would have to retain the stock PCM for that, power steering, gauges, and possibly airbags and ABS.
Old Aug 14, 2008 | 02:49 PM
Omega_5's Avatar
Quit pissing around with that AEM junk...
http://www.motec.com/
Old Aug 14, 2008 | 02:51 PM
BOOSSTED 06's Avatar
AEM EMS is very nice, I have many customers ask for it. But liek Omega said Motec has amazing products with the best lineup of features on the market. Ill actually be using thier setups in a couple of the shop cars
Old Aug 14, 2008 | 02:53 PM
Omega_5's Avatar
I'm partial to Motec... I learned on it... and have had great support from them.
Plus, look at all the goodies they make!
Old Aug 14, 2008 | 02:54 PM
yup, like i said we are going to be using this on the lexus and on the MG, havent decided on the other cars but yeah with all the addons they are the best option
Old Aug 14, 2008 | 02:55 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Bigstuff3 will supposedly work with the stock controls, PCM/BCM's of the Cobalts. Of all the options they are supposed to be as close to plug and play as your going to get but it is also the most expensive.
Old Aug 14, 2008 | 02:57 PM
bolus's Avatar
Thanks, guys, I had not heard of Motex before. I'll look into these others and post back what I find.
Old Aug 14, 2008 | 02:58 PM
Witt's Avatar
It would have to support J1850 VPW and at least GM low speed lan to retain ecm->bcm functionality iirc.
Its been quite a while since Ive hashed over this.
Old Aug 14, 2008 | 03:02 PM
Omega_5's Avatar
Your and evo guy... have you checked out their line of AWD diff controllers? Pretty sweet stuff... and I imagine they'll have support for the EVOX pretty soon, as well.
Old Aug 14, 2008 | 03:05 PM
Yeah we will be going stand alone on the evoX later this year so thats when I will start getting in contact about that. That would be the third car in the shop we are goign stand alone.
Old Aug 14, 2008 | 04:14 PM
Speedytec's Avatar
I assume you want to run this ECU in your LSJ powered Atom, so it only has to run the engine. No worries for BSC, airbag, ABS etc...
But to make life easy with the ECU's I would change to a cable operated throttle. I think the Honda powered Atom's have a cable throttle, so you can probably use that set-up.
Maybe change to a distr. set-up if necessary.
Old Aug 14, 2008 | 04:19 PM
bolus's Avatar
Yeah, it only has to run the engine
bigstuff3 replied and they said they have a cobalt race car with their ECU running it. But it requires "some fabrication" I'm looking into what that would entail.
I also got a contact to talk to over at Hydra EMS
I'm hoping to use the stock sensors, throttle and coil on plug.
Old Aug 14, 2008 | 04:21 PM
Omega_5's Avatar
Originally Posted by bolus
Y
Jeg's 6 sec drag Cobalt.
Old Aug 14, 2008 | 04:29 PM
Area47's Avatar
Rent me! per hour
cop is easy. a flying lead standalone is the easiest to work with. convert the tb to a cable set up. aem, or bigstuff is used in the drag cobalts. depending on which version of the cook book you read. i know aem can read the pick up.
Old Aug 14, 2008 | 04:59 PM
bolus's Avatar
Bigstuff3 says I would need a 24x wheel so that one is out.
Old Aug 14, 2008 | 05:47 PM
Area47's Avatar
Rent me! per hour
fast, or aem. if you're really creative, hks v-pro
Old Aug 14, 2008 | 06:04 PM
bolus's Avatar
I have a local dealer that installs both motec and HKS so i'll see what he has to say tomorrow
Old Aug 15, 2008 | 04:20 AM
Speedytec's Avatar
You can always bolt-up the correct timing wheel + sensor to the pulley. (so outside the engine)
Why do you want to go stand-alone now? The tuned GM Ecu you had in there is not OK for your turbo LSj set-up??
Old Aug 15, 2008 | 04:46 PM
bolus's Avatar
I dont really want to bolt a wheel outside the engine. It would fully exposed to road debris.
I just want another project for this winter. And full flexibility in the ECU programming. Plus the ECU is too limited to SD tune and I'm maxing out the maf. So I either spend a bunch of money on custom parts to fix the MAF issue or spend money on a new ECU..
I spoke with a local motec dealer and his tech. He says that the M400 should work after we reviewed the sensors. It would need a custom harness though they have one available that is basically 10 feet of pre-labeled wires and connectors. So far this seems the best option. Probably the most expensive though.
Old Aug 15, 2008 | 08:51 PM
TurboTechRacing's Avatar
Electromotive TEC3 here 2.2L Ecotec Cavalier....
Motec would be a 2nd choice, followed by Fast.
Old Aug 15, 2008 | 09:04 PM
Josh@ottp's Avatar
I personally would put a gm e67 in it. It will control everything you need, is very flexible and hptuners is adding tons of support on top of what they already have because the pcm is in alot of cars. I've used bs3 and the gm pcm has way more to tune on a street car.
Old Aug 15, 2008 | 09:13 PM
bolus's Avatar
Now that's an interesting idea. that's off the 2.4L LE5 right? Do they have compatible crank sensors and reluctor wheels?
