Standalone ECU options for LSJ?
Old Aug 15, 2008 | 11:50 PM
Josh@ottp's Avatar
Originally Posted by bolus
Now that's an interesting idea. that's off the 2.4L LE5 right? Do they have compatible crank sensors and reluctor wheels?
Yes it's used in the 2.4. I'd have to look but there both ecotecs so I would think the sensors would swap easily. That pcm is also used in some of the v8's
Old Aug 16, 2008 | 12:00 AM
Area47's Avatar
Rent me! per hour
the 2.4 reluctor wheel is different i believe. someone on here went through hell to get a 2.4/lsj setup to work right. quick idea. take the stock crank pulley, drill holes in it, have the holes filled with magnets, and find a shallow pick up and stick on there. old honda trick
Old Aug 16, 2008 | 09:12 AM
Doc's Avatar
Doc
mvp used a combination of parts on his hybrid engine....I forget who bought it from him though
stryder would know more about it
Old Aug 16, 2008 | 11:00 AM
Josh@ottp's Avatar
Just checked, they both use 58x.
Old Aug 16, 2008 | 11:35 AM
bolus's Avatar
My brief look through a stock LE5 tune from the tune repository looks like SD tuning is more limited but the MAF table has a higher frequency range by a little (12200 instead of 11000) so that helps me a little. It may still be a good stop gap until I get a standalone. Plus used LE5 ECU's are $60 on car-part.com
Old Aug 16, 2008 | 11:58 AM
Josh@ottp's Avatar
They are working on 2 and 3 bar OS for the e67 right now and also the maf should double just like the e38's. Look at these
http://www.hptuners.com/forum/showth...hlight=e67+bar
The e67 is being worked on right now.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
goaliemo
Sep 28, 2015 01:37 PM
