start then no start HELP
Old Jan 23, 2011 | 08:31 PM
OiangeSS's Avatar
ok so my dad went and started my car yesterday to move it he said it started fine then shut it off then later on i went out to start it to go to work it started for a sec then shut off went to crank it over again and nothing, i can feel the crank turning just sounds like no spark. now i replaced the plugs 2 months ago with NGK step 2 colder plugs ive tried to jump it and it does the same thing i dont know where to start on trying to get it started i thought about smacking the started with a mallet but if the crank is turning then the starter isnt messed up right ?
Old Jan 23, 2011 | 08:36 PM
CoreySS07's Avatar
Did you check to see if your fuel pump is working?
Old Jan 23, 2011 | 08:37 PM
OiangeSS's Avatar
not yet its 8 degrees outside lol
Old Jan 23, 2011 | 08:39 PM
CoreySS07's Avatar
oh haha I just suggested it because its -15 here and the fuel pump in my truck pooped out on me haha
Old Jan 23, 2011 | 08:40 PM
OiangeSS's Avatar
im going to go check here in a sec ima see if i can here it running
Old Jan 23, 2011 | 08:45 PM
OiangeSS's Avatar
ok fuel pump runs it started for a hot sec again REALLY bad idle for how long it ran and a lil bit of knock due to not being ran and no oil getting up to the in it for two days
Old Jan 23, 2011 | 09:13 PM
OiangeSS's Avatar
Old Jan 23, 2011 | 10:08 PM
OiangeSS's Avatar
bump i need to get my car running
any ideas
Old Jan 24, 2011 | 02:22 PM
OiangeSS's Avatar
afternoon bump any help ?
Old Jan 24, 2011 | 06:02 PM
Coblasts's Avatar
Remove the plugs and clean the carbon off them.
Your dad starting it and shutting it off before it got to operating temp fouled the plugs most likely
These car run really rich and on cold starts its really bad.
Old Jan 24, 2011 | 11:27 PM
OiangeSS's Avatar
ok thanks im goin to do that wed and i have a friend coming over to check my fuel pressure bc i dont have a checker
Old Jan 25, 2011 | 02:56 PM
OiangeSS's Avatar
thank you much appreciated i pulled two plugs first then started it. ran like **** so i pulled the other 2 cleaned them off it ran like **** for about 5 min (im guessing bc it hadnt been started in 3days) the plugs smelled like gas from where it was flooded from tryin to start it so much
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
