stock boost gauge 4 wires which is positive and which is negative?
Old Apr 2, 2009 | 08:49 PM
StockSS's Avatar
^top
there are 4 wires on the stock boost gauge. i am installing a wideband and nitrous pressure gauge and wondering if i can tap into the stock gauge for ground and power?
anyone know?
Old Apr 2, 2009 | 08:54 PM
Maven's Avatar
Pink is Ignition switched, Black/White is ground.
Old Apr 2, 2009 | 08:58 PM
StockSS's Avatar
so i can run 2 more gauges off the pink wire for power and black/white is the ground?
Old Apr 2, 2009 | 09:03 PM
Maven's Avatar
Pink is power, blk/wht is ground, depends on how much power your gauges need if you can do it safely though, but thats the info you need
Old Apr 2, 2009 | 09:11 PM
StockSS's Avatar
you wouldn't happen to know if the reflector that's orange in the headlight if you can somehow get at it w/o opening up the whole headlight would you?
bigdeertz
Nov 17, 2016 09:41 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
jcarroll53
Sep 24, 2015 07:43 PM
Cptnslo
Sep 24, 2015 09:32 AM
dennis69
Sep 23, 2015 02:56 PM
