stock downpipe
Old Apr 28, 2008 | 08:00 PM
YellowRocketSS's Avatar
stock downpipe
does anyone know the size pipe that they use for the stock downpipe?
Thanks guys
Old Apr 28, 2008 | 08:05 PM
ItalianJoe1's Avatar
Most of it is 3" I believe. It gets crimped down inside and at the exit, but the outside piping is quite large.
Old Apr 28, 2008 | 08:06 PM
ok i wasnt sure if it was 2.5 or 3
Old Apr 28, 2008 | 08:09 PM
bigger than 2.5", id say about 2.75 or 3". I'd go measure my stock one but its up on the loft in the garage.
Old Apr 28, 2008 | 08:16 PM
ok cuz im gettin my custume exhaust put on tom and i wanted to know what size pipe to run from there back
Old Apr 28, 2008 | 08:39 PM
If you plan on keeping the stock DP, 2.25 or 2.5 I sufficent. The DP is quite restictive, and unless you plan on changing it to a 3" piece don't run 3" the rest of the way out. For one you may have sealing issues as the stock unit is designed to bolt up to a 2.5" system.
Old Apr 28, 2008 | 08:51 PM
ok ya i was thinking 2.5 all the way back to my mufflers which are 3. Im getting it all welded so it hopefully wont leak.
Old Jun 26, 2008 | 04:41 PM
Shanman's Avatar
is the ss s/c downpipe the same as the 2.4 or 2.2?
Old Jun 26, 2008 | 04:42 PM
an0malous's Avatar
it has the flow of a drinking straw
Old Jun 26, 2008 | 04:45 PM
chad463's Avatar
ahah thats for sure, I found a big difference in flow when I changed my downpipe
Old Jun 26, 2008 | 04:50 PM
Zach06CobaltSC's Avatar
When my custom exhaust was made, we deleted my downpipe and just used 3 inch exhaust pipe from where the downpipe was, all the way back to the tail pipe, with no cat, and a magnaflow muffler. I noticed a big gain. Then when I added the zzp header/downpipe/cat I noticed an even bigger gain, but a slight loss in boost, which is good. I still hit 15lbs with the stage 2 kit so I am happy.
I have all the mods in my sig installed minus the meth, that is apparently getting finished tomorrow morning and were doing dyno runs then.
Old Jun 26, 2008 | 05:04 PM
Shanman's Avatar
is the 3 bolt flange on the downpipe that hooks to the manifold the same with the 2.0 and 2.2's?
Old Jul 1, 2008 | 06:13 PM
Shanman's Avatar
is the downpipe for the s/c the same for the 2.2
Old Jul 1, 2008 | 07:28 PM
Yes, it is.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
