From stock to tvs?
Old Aug 9, 2010 | 01:00 PM
Render2009's Avatar
From stock to tvs?
How much am I looking to spend
Old Aug 9, 2010 | 01:02 PM
coopercharge's Avatar
atleast 2500 bucks for tvs, injectors,plugs,tune.
Plus any supoporting mods such as single pass, clutch, driveshafts, larger heat exchanger.
Old Aug 9, 2010 | 01:09 PM
BlackMagic's Avatar
cheapest was go ottp stage 3 its 2200
Harrop TVS Supercharger with 3.14" pulley(option to add others)
80lb Flowmatched Injectors
Injector Harness
Larger Idler Pulley or Stage 2 Belt (option)
NGK 1 Step Colder Copper Plugs
OTT Stage 3 PCM
if it were me i would also do a heat exchanger and you should be fine
Old Aug 9, 2010 | 01:18 PM
sjc0013's Avatar
Window Licker
Definitely go ottp stage 3 unless you get an amazing deal on a tvs. So it will be atleast 2200 plus you want a custom tune so probably another 300 on top of that.
Also, youre gonna want supporting mods which depending on what you want could be another 2k. (intake, heat exchanger, single pass, header, dp, exhaust)
Make sure you get enough cooling mods
Old Aug 9, 2010 | 02:25 PM
Render2009's Avatar
So about 5k cus I'll have to get a clutch to?
Old Aug 9, 2010 | 02:57 PM
Bluelightning's Avatar
Got Bewst?
Drive it on the stock clutch till you burn it out. Might as well. But ya to do everything properly you'll be looking at about 5k
Old Aug 9, 2010 | 04:48 PM
BlackMagic's Avatar
i've spent right under 3500 and I am pretty well set up. definitely more than just the necessities to get you going.
(black friday sales ftmfw) bought about half my parts that day.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
