Straight Cut Gears
ONE M-22's are not straight cut, im so sick of hearing this its pissing me off. they are cut at half the angle (22.5* rather than 45*)
Two, do you really think it would be as loud in a FWD cobalt as it is in that race car. if you got 22.5* gears and cryo'd em. with all the insulation and the fact that the trans isnt under your feet like a RWD car. it wouldnt be even as loud as the older 'birds the other guy posted.
Why not swap to a f23? I know most of the high horsepower cavaliers (400+) use them, myself included (I have 474 whp). The only thing done to ours is an OBX LSD differential. Hahn used them on their cavalier with 600+ hp.
Guy's straight cut gears are not going to fix this issue. going from helical to straight fixes two primary modes of failure; excessive bearing wear, and gears stripping the teeth from only half the gear because they are side loaded so much that the push partially out of mesh while in gear (well I guess theres a 3rd and that would be pushing the whole input or output shaft through the trans case). If you're stripping all of the teeth off your gears are either too soft, have a stress risers on one tooth causing it to fail then cascade fail rest of the gears from shock loading, or your trans case is flexing and letting the gears pull apart and have less of each tooth in contact until they fail. Hardening the gears will fix the first two, the third would need a better transcase, or maybe some bracing could be welded on by a pro but it would be super hard to not warp the case, or it may be possible to send the case out to be harden but then you may end up cracking the case with wheel hop or some other jazz.
Or if you really want stronger gears without the side loading like straight cut gears but without the noise, consider some herringbone cut gears, a set should only run you like 50 grand.
Edit... the case bracing makes the most sense to me. If it was pure torque that was breaking them 2nd would go all day long. But if 3rd is seeing all of the twist in the case and pulling away it would be just like my rc car when the spurr gear sets too far back from the bell. strips all the teeth off instantly. Don't matter how hard it is if it's not making proper contact. Clearances are the key
I can drive? haha that actually made me laugh thanks
Looks legit man. I like the colors haha
DANRICKARD
Oct 1, 2015 12:08 AM
