Strange noise... HELP
Old Jul 16, 2009 | 02:29 PM
ajm5036's Avatar
I get this strange noise only when I accellerate. There is no effect performance wise. But its this kinda of ticking noise and as I accelerate the rate of the ticking gets faster untill its eventually drowned out by the exhaust. I think it could be something loose in my Hahn high flow cat. WHat do you guys think? ANyone have any idea?
Old Jul 16, 2009 | 02:34 PM
SCcobaltSS's Avatar
Do you have a header? sounds like an exhaust leak.
Old Jul 16, 2009 | 02:38 PM
rallyracer's Avatar
Check to see if you have a nail in one of your tires.
Old Jul 16, 2009 | 02:40 PM
ajm5036's Avatar
I do I have hahn header, downpipe, and exhaust. You think exhaust leak? I could imagine this is what it would sounds like.
Its definalty not that kind of sound it has something to do with the exhaust because its more of an air noise, not a physical tapping.
Old Jul 16, 2009 | 02:57 PM
Staged07SS's Avatar
Administrator
Administrator
deff sounds like an exhaust leak .... check your downpipe to catback connection. mine used to leak there when i had the cti 3" downpipe.
Old Jul 16, 2009 | 02:58 PM
SCcobaltSS's Avatar
If it goes with the RPM of the engine yes.. Have you checked the torque of the header bolts?
Old Jul 16, 2009 | 06:15 PM
ajm5036's Avatar
[QUOTE=SCcobaltSS;4119281]
I do I have hahn header, downpipe, and exhaust. You think exhaust leak? I could imagine this is what it would sounds like.QUOTE]
I will now, your trying to say they could be loose?
Can anyone else confirm having this problem and hearing this sound because of a loose manifold?
Old Jul 17, 2009 | 12:26 AM
Staged07SS's Avatar
Administrator
Administrator
[QUOTE=ajm5036;4119368]
i said i had the same problem a couple of posts up .... check all of your connections and make sure they are tight. also check to make sure the gaskets are ok and are not damaged or blown out in anyway.
Old Jul 17, 2009 | 11:43 AM
SCcobaltSS's Avatar
I had the same problem also, just tighten them down and tighten from the passanger to drive every other bolt. Make sure it is aligning correctly when you tighten it.
Old Jul 17, 2009 | 11:46 AM
XM15's Avatar
Sounds like an exhaust leak to me as well. I had one a while back when I had my header installed, and it sounded like you described.
For a week or so my car sounded like a model-T. lol
Old Jul 17, 2009 | 11:48 AM
SCcobaltSS's Avatar
^hahaha that is one of the best descriptions I have heard!
Meadowvalien
Aug 17, 2017 06:32 PM
jcarroll53
Sep 24, 2015 07:43 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
