Stroker LSJ Turbo
Old Jan 26, 2014 | 01:55 AM
OG_SS05's Avatar
Stroker LSJ Turbo
Finally decided what I'm doin to this 'Balt.
Ecotec Forged Short Block
2.4L Stroker LSJ Turbo Gen 3
ZZP Neutral Balance Shafts
Aluminum Flywheel for stroker
ATI SFI Turbo Balancer
Add ZZP 4340 Rods
JE 9.1:1 Pistons
80# OTTP Return Style
ZZP S2 Cams
ZZP 82#vs Titanium Retainers
Elec. Water Pump
Deatsch Werks DW300
ZZP Turbo Kit
PTE 6262 .63 or S259et .55(haven't decided)
3.5" Straight Pipe
PTE 46mm Wastegate
Pump Gas
Cam Gears
etc etc. not everything just pretty much engine build. What do you guys think. income tax is right around the corner and imma have a chunk of change to spend. input is welcomw
Old Jan 26, 2014 | 01:59 AM
andrewcarr1993's Avatar
What shop?
Old Jan 26, 2014 | 08:35 AM
OG_SS05's Avatar
What shop?
huh?
Old Jan 26, 2014 | 08:38 AM
mrbelvedere's Avatar
Add ZZP 4340 Rods
JE 9.1:1 Pistons
ZZP S2 Cams
Elec. Water Pump
Deatsch Werks DW300
ZZP Turbo Kit
3.5" Straight Pipe
PTE 46mm Wastegate
Pump Gas
Cam Gears
the injectors wont be big enough you'll need a set of 1200cc minimum you can get them from alan I would get a better set of cams you will need a bigger fuel pump start with a wallbro 450 you do not need nbs shafts with ele water pump just plug the holes with a set of stockers and and stick with the 6262 you do not need 3.5in strait pipe 3in will be plenty as for springs I would run super tech 94#
Old Jan 26, 2014 | 08:34 PM
OG_SS05's Avatar
so basically it would be a balance shaft delete? and yea I've done a little more research on the fueling and your right 1200cc should be enough. as for the exhaust I had some piping left over from my old s366 rx7. I thought 94# wouldn't fit on the ecotec engine? my head is ported and polished already with 1mm oversized valves, and brand new oem lifters. no a/c. so if I done the bs delete and the ewp I would have a belt for the alternator and the tensioner only right? I think the s2 ZZP cams should be good tho. not a track car just weekend toy/quarter mile every now and then. plus I love beating people in a cobalt lol😉
Old Jan 26, 2014 | 08:49 PM
574's Avatar
574
**** yea. One thing to think about, forget the ewp and just run nbs. More load= quicker spool Thats a healthy turbo
Old Jan 26, 2014 | 09:18 PM
that's not enough load to help it spool faster it would be more of a benefit if the mechanical pump was not there as the engine will rev faster and that will induce more load
op if you run a ele water pump you do not need a shorter belt the wp is run off the accessory chain inside the engine and if you run an ele water pump you do not need nbs or a delete just stick the stock balance shafts in place to plug the oil feed holes
Old Jan 26, 2014 | 09:46 PM
OG_SS05's Avatar
ohhhhhtay so your saying the stockers will plug the holes but not be run off the accessory chain? but I'd still need a shorter belt right? if I wanna take off rotating mass I wanna do it right. I think I know where your going with this lol I'm not very familiar with the lsj engine hahaaa :p
Old Jan 27, 2014 | 08:12 AM
yes the stock balance shafts will plug the holes and you will need a belt from 2.2 I believe
Old Jan 27, 2014 | 08:20 AM
Tjolley's Avatar
OP one thing to remember is the 2.4 crank really hasent been pushed extreamly hard yet.
I have a 2.4 with a lsj head. But I'm sc I'm affraid of breaking the crank. Just something to think about.
U might consider a 2.1 and hang that 6262 off the back.
Old Jan 27, 2014 | 09:27 AM
Crank should be fine to around 600whp is what ive been hearing for years
Old Jan 29, 2014 | 08:23 PM
OG_SS05's Avatar
yea haven't really though about that. I think I might go 2.1. but I wanted to see what a stroker lsj turbo could do. fully built pte 6262. sounds like a hell of a time
Old Jan 29, 2014 | 08:33 PM
taintedred07's Avatar
Do it, be different
Old Jan 30, 2014 | 08:24 AM
Tjolley's Avatar
True.
Problem with the 2.4 bottom end is the rods r very short. That isnt good for rpm. It will add a tremendous amount of stress to the crank.
That's y I'm using 2.2 l61 rods and custom pistons.
Old Feb 1, 2014 | 09:19 PM
OG_SS05's Avatar
well guys taxes are done and I got 8 grand to blow. started yesterday on this lsj engine I had sittin in the garage. it had 80k when the previous owner wrecked it. I'm wanting to do something simple but make a couple ponies. my buddy has parts from his old lsj for sale as follows:
9-1cr pistons
zzp nbs
vortex? (idk) cams
zzp 4340 rods
built head all titanium
full 3"mpx exhaust (turbo dp)
zzp ic
4.45 LSD tranny
and a old gt40r turbo. he was revving to 8k but supposably hitting full boost at 6500. he said he made 450 on a mustang dyno @23psi. idk. but his setup was pretty badass. what do y'all think about it? he's letting me have everything for $650 minus the tranny. so I really wanna do it. I would have the same setup but a different turbo. my 6262. lmk guys
Old Feb 2, 2014 | 03:49 PM
I would not run the jbp cams go ottp zzp or custom I would also run a nbs delete and put a good set of sleeves in it
Old Feb 2, 2014 | 05:42 PM
OG_SS05's Avatar
what kind of sleeves are good? and who sells a nbs delete? or what would I need? I have access to a garage and his tools
Old Feb 2, 2014 | 06:18 PM
Level zero motorsports sells balance shaft deletes or zzp makes neutral blank shafts.
The guy above you is the one to talk to about sleeves.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
maliki778
Oct 1, 2015 07:39 PM
