subaru sound of death question
i was driving the car yesterday and was having a little fun. was driving it a little aggressive, didnt go over 6500 RPM. it missed a couple times and went rich. parked it and looked at the engine, looked fine. went to start it and had the feared subaru sound
. so now it is just sitting there.
my question is, if i pull the valve cover and take out the rocker or lash adjuster(whichever broke/fell off) and pull the plug on the injector, would it be ok to drive it a mile on 3 cylinders?
might be a stupid question but where it is parked i cant really work on it or have it sit for an extended amount of time.
pretty similar to this....My supercharged cobalt with cylinder 3 piston ring out - YouTube
my sunfire made the same sound and i ended up changing the engine not knowing what was wrong, heres what it sounded like to give everyone a better idea
VID 20110605 00002 - YouTube
have you done a compression or a leakdown test yet? is the dipstick popping out? how do you know you broke a follower or had one kicked out i broken follower wont make the dipstick pop but a broken ringland will if you are not having a stick popping problem try replacing the plugs it could be that its tie for a new set
have you done a compression or a leakdown test yet? not yet comp test tomorrow is the dipstick popping out?no how do you know you broke a follower or had one kicked outi dont know yet, pulling valve cover tomorrow. i am just assuming based off of other peoples expirence i broken follower wont make the dipstick pop but a broken ringland will if you are not having a stick popping problem try replacing the plugs it could be that its tie for a new seti will be looking at these tomorrow also
When that happened to my Civic, it was a cracked ringland..
Is there blowby coming from the valve cover/oil filler when u open it?
Update:
Went out there and pulled the valve cover off and looked in. There were no rockers or lash adjusters off or broken. Had me worried that it was a piston now. Did a compression test and here are the results 1-4,
1- 198
2-200
3-190
4-195
Now I know you are supposed to do this with a warm engine. Mine was cold. How much of an effect on the numbers would this cause?
I also let the pressure sit there on each cylinder a little bit to see if they dropped and none of them did.
Also, the plugs that I pulled out looked ok I will post pics of them later.
So after all the I figured I would put her back together with new spark plugs gapped to .034. Got everything together and she started right up and ran completely normal!! Idk if a coil was loose or what but no more Subaru sound!!!!
1- 198
2-200
3-190
4-195
