Sudden loss of 8-9psi?
As late as Jan the car was making upwards of 26psi, somehow in the past few weeks something has changed. Its way more than just weather something else is going on and I cant figure out what it is. Car isnt running bad its just only getting 15psi tops.
Anyone have a clue here? I've gone over vac lines and all that, running the exact same tune as I have for the past year or so. I'm stumped, im not getting any codes.
Definitely a slight boost leak somewhere. If you have a boost leak test try that and see if you can feel/hear air leaking anywhere.
Edit: I just saw you have a TVS, idk if a boost leak test works for you.
the boost bypass is not even 6 months old
I was on a 2.8 pulley, and that was in very cold weather, granted being warmer now I expect it to be lower, but not less boost than I made with the 3.5inch pulley
well i think i found the culprit, not what I expected given its less than 6 months old, bypass valve is shot
I push it in and it doesnt even spring back like its supposed to, I guess I'm glad its that and not something more expensive
twilson380
Sep 14, 2015 10:52 AM
Adam144
Sep 3, 2015 07:48 PM
