Super Charger Gasket !
Old Apr 19, 2009 | 08:26 PM
QuickSilver_SS's Avatar
Post Super Charger Gasket !
Has anyone had to change one of the gaskets that the super charger sits on ? I just added a cobalt addiction heat exchanger and i seem to be going through alittle bit of coolant sense i put it on yesturday. I DO NOT have any leaks anywhere's at all. I double checked all the connections and tried to tighten them. Everything was good. No coolant on the ground. And the super charger gasket isn't leaking on the outside. Could it be leaking internally pulling in coolant into the super chargers air ? Or are there any other seals and or gaskets some where in there ?
I checked my oil and it isn't milky at all and i don't seem to have any excess white smoke from my tail pipe and it smells normal.
Any thoughts ? I find it weord that i add a heat exchanger and now i need a new chargere gasket. The car has about 46,000 ish miles.
Old Apr 19, 2009 | 08:32 PM
2006blackss's Avatar
It sounds like you are maybe just bleeding off the air in the system.
Old Apr 19, 2009 | 09:10 PM
StevesBlack06's Avatar
how long has it been since you put on your h/e? ifi it hasnt been long keep toppin it off. it will bleed that air off after a lil while and you will level out.
Old Apr 19, 2009 | 09:21 PM
I finished it installing ot and filling it up at about 9:00 p.m yesturday. I drove alitlle. Maybe 25 miles.
Old Apr 19, 2009 | 09:22 PM
advise's Avatar
ya that gasket has nothing to do with your cooling it only would create a boost leak
Old Apr 19, 2009 | 09:34 PM
Hhhhhhmmmmm....... I'm kinda confused then ! That makes sense what your sayin that the gasket has nothing to do with the antifreeze. I don't have a boost leak at all ! Could i be really still bleeding air after almost a full day ? Cause i know im not leaking it !
Old Apr 19, 2009 | 09:41 PM
advise's Avatar
ya i wouldn't doubt it you should do a reservoir swap and solve your problem
Old Apr 19, 2009 | 09:47 PM
Snakes709's Avatar
everything is fine. It just takes time for the air to bleed out of the system, after i put my h/e on i let the car run for 30mins and then kept filling it and watching the air come out of the IC Res. Then once i was driving everytime i stopped i would check it again.
Old Apr 19, 2009 | 11:37 PM
What do you mean resivoir swap ?? How would that solve my problem ? Does anyone a;se think it could just still be bleeding air ? I am still using the stock filler neck .
Old Apr 21, 2009 | 11:32 AM
Well, i have let my car idle for nearly 2 hours today . With the cap to stock filler neck off and i still seem to be getting little tiny bubbles off air at the top of the fluid. Really small bubles. But alot of them. The pump is flowing for sure !!! I just CAN NOT seem to bleed this system. When i put the cap back on and drive the car for a short run the level in the filler neck drops slightly. When i turn off the car and take the cap off the level rises again?? Is that normal ?? Please help. I have topped this thing off like 10 times !! I dont seem to be leaking onto the ground anywheres ! Maybe the motor is pulling in the antifreeze ?? But i cant see how at all !!! Any help would be great ! Thanks guys !
Bump for ANY help !!!!
Last edited by QuickSilver_SS; Apr 21, 2009 at 11:32 AM. Reason: Automerged Doublepost
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
