supercharger chatter
so what makes the s/c chatter at idle? its really freaking annoying and i feel like its going to fall apart and blow up. it goes away when its boosting, but as soon as it goes back to vacuum it makes the noise.
i looked up coupler from zzp and i guess it should be, i suppose ill be ordering it. thatll teach me to buy someone elses s/c, oh well.
if you could assist on a "how to" that would be nice. thank you good sir
nevermind!
https://www.cobaltss.net/forums/show...oupler+install
nevermind!
nevermind!
nevermind!
Another thing to suspect is the belt tensioner, check that for play in both the bearing and the mount.
The timing belt tensioner also screws up like clockwork on these cars, but it sounds more like valve knock/ticking
I'm sure you've already found out how to check it to see for sure if it's the coupler, but in case you didn't, pull the belt off and rapidly twist the pulley left to right - if you feel play or a "loose connection" between it and your blades, it's the coupler.
im putting my ear right to the s/c and thats where all the noise is coming from. i didnt notice any play when i put it on the car, but oh well, ill atleast give it a try, whats 50 bucks yeah?
Are you 100% certain that it is the blower making the noise? My serpentine belt stretched out once and it was causing the tensioner to chatter. Changed the belt and that fixed it. However it only chattered shen you blipped the throttle.
z28addiction
Sep 28, 2015 12:03 AM
