supercharger flutter?!!?
Old Jul 31, 2006 | 10:45 PM
*TRIX*'s Avatar
ok so if anyone had this problem i figured out what it was
i wasnt running the boost bypass cause i have a special hptuners cobalt-addiction tune and i had no problems with my boost up untill the other day
i had 17lbs of boost at full throttle and when i hit 5400rpm it started to drop and by the time i was at 7400 it was at 10psi
the stock boost bleeder on 05's it seems cannot support 20lbs or more without breaking the internals and letting out massive amounts of boost I am the second person to see this problem that i know
soo i dont know about anyone else but i have to leave the boost bypass on even with my tune
so i dont loose massive amounts of boost
Old Jul 31, 2006 | 11:28 PM
beamSS's Avatar
why were you redlining over 7k rpm?
Old Aug 1, 2006 | 01:41 AM
leviticus88's Avatar
what does this sound like, flutter that is? Since, I installed my CAI my sc has been making a sound when at a quarter throttle that sounds like a bristle brush across a ruff surface but when I go wot it stops. Is this what your talking about, or something diff/normal?
Old Aug 1, 2006 | 01:47 AM
Rangerondubz's Avatar
your belt could be slipping, have u upgraded anything else besides the pulley? belt? tensioner? that sounds like your problem b/c the boost is slipping off at a higher rpm b/c it is getting harder to turn the s/c that fast
Old Aug 1, 2006 | 03:15 AM
silverSS's Avatar
yeah....and what makes you think the internals cannot hold more than 20lbs?????????????
Old Aug 1, 2006 | 09:50 AM
*TRIX*'s Avatar
ok i had a reg belt and tensioner and i thought it was slipping so i moved it to the max position and i still got flutter so i went out anf bought a stg 2 belt and it still didnt fix it and i thought it was slippage at first as well
i unbolted the supercharger and intake plenum to see if my gaskets were shot and they were not sooooo i said to myself why dont i look at the boost bleeder
i then took apart the boost bleeder to realize the internals were shot
Old Aug 1, 2006 | 09:51 AM
patathSS's Avatar
I have no problems with my 05.
Old Aug 1, 2006 | 09:53 AM
*TRIX*'s Avatar
cause i know my car
Old Aug 1, 2006 | 09:55 AM
*TRIX*'s Avatar
yeah i know but i also know I am the second person in my area to have this problem
Old Aug 1, 2006 | 10:01 AM
Ramps's Avatar
what are you reving to? is 7400 what you set the limiter at? I have the HPtuner on order and i was going to set it at 7300 but if higher has been safe and it still makes power up there i will set it higher.
Old Aug 1, 2006 | 10:05 AM
06blackg85ss's Avatar
I know that suxs dude... but you were runnin 100% boost in all gears anyway, so its not gonna have much of an effect doin the bypass mod... I"ll see if I can get you a rebuild kit if you want... and I know there is no way in hell that belt is ever gonna slip again.... I could barely get that **** on....
Old Aug 1, 2006 | 10:06 AM
we're both runnin 7400 and so far no internal engine damage... though I try not to rev it that high
Old Aug 1, 2006 | 10:07 AM
*TRIX*'s Avatar
7400 yep and im still making power and my a/f is safe and im not getting heatsoaked at all
Old Aug 2, 2006 | 09:01 AM
patathSS's Avatar
Mine is set at 7400. I don't get heat soak from the revs, I get it from the pulley. Which I guess is a result of the revs....
Old Aug 2, 2006 | 09:33 AM
true.... I run a 2.6 on the street, never really had any probs plus I usually shift at like 2k anyway.
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
breds2k
19
Sep 21, 2015 10:24 AM
