supercharger holes
Old Jan 15, 2009 | 10:48 AM
scott allen's Avatar
supercharger holes
Does pluging the 2 holes under the supercharger gain any power?And how much more louder does it get?Any before and after dyno test been done?Any videos? Or pics,If this is a repost my bad.
Old Jan 15, 2009 | 10:50 AM
chris88z24's Avatar
no power
increased efficiency
yes its louder
Old Jan 15, 2009 | 10:51 AM
Zach06CobaltSC's Avatar
All it basically changes is the sound, it makes the whine a little bit louder.
tombomb's Avatar
search...there is lots of info and threads on this. there is a "how to" and it has pics and vids
Old Jan 15, 2009 | 10:53 AM
lsjwannabe's Avatar
The “back-flow” slots were on the earlier Eaton designs as it reduced the back-flow event, which reduced noise (slightly). Plugging the slots does improve flow, but ever so slightly. The impact from an efficiency standpoint is negligible. I would be more concerned with the method of “plugging” the slots as welding will of course distort the housing and using aluminum filler runs the risk of coming loose, thus resulting in a destroyed unit altogether. In my opinion it’s not worth the minimal gains vs. the risks in plugging the slots.
Old Jan 15, 2009 | 10:55 AM
no power
yes its louder
Cool thanks man.But if it increases the effciency would that in return increase the power?
Ok thanks. Ill leave it be .
Last edited by scott allen; Jan 15, 2009 at 10:55 AM. Reason: Automerged Doublepost
Old Jan 15, 2009 | 11:03 AM
Dainslaif's Avatar
No, not really. It's like 1% efficiency, so you literally won't notice it.
Old Jan 15, 2009 | 11:12 AM
Not only would you not notice it, it won't increase performance. Horsepower and efficiency are two different things. The air will be able to flow over the surface easier without the holes, but the same amount of air is moving so there is no increase in power. Now if you were to port it, there would be more air moving through it, thus creating more power.
Old Jan 15, 2009 | 12:42 PM
Jkunzy1690's Avatar
i thought a port job was an efficiency thing rather than power....hmmm- idt you would see much of a hp gain unless you got a port job and a 3 inch intake?
Old Jan 15, 2009 | 03:43 PM
tdipowered's Avatar
yea seems kinda risky for what you get...the blower is pretty loud with just an intake
GaryGibblez
Jan 14, 2020 10:35 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Slick_Nick
Sep 28, 2015 09:15 PM
z28addiction
Sep 28, 2015 12:03 AM
