Supercool that Intercooler!
Pretty neat idea that someone should adapt into the Cobalt SS
http://www.fast-autos.net/ford/fordl...ngconcept.html
Ford's patented SuperCooler technology cleverly provides a special burst of power for the SVT Lightning concept. Traditional intercoolers dissipate heat from the supercharged air by circulating coolant through a front-mounted, air-cooled radiator. With the SuperCooler system, the vehicle's air conditioning system is used to chill a small storage tank of coolant to about 30 degrees Fahrenheit.
On demand, the SuperCooler system switches the intercooler flow from its normal circulation and dumps the chilled coolant into the engine's intercooler. In turn, the intercooler dissipates up to 20 percent more heat from the charge air - resulting in a denser air charge.
A green light on the instrument panel indicates the system's readiness. SuperCooler is activated automatically when the driver depresses the accelerator to a wide-open-throttle position.
"This technology plays directly into the hands of the enthusiast," Coletti says. "The SuperCooler provides the edge for the driver, and it is done simply by taking advantage of the hardware that already exists in the vehicle."
As a result of this cool technology, the SVT Lighting concept can give its driver as much as 50 transient horsepower for short bursts of 30-45 seconds and regenerate within 2 minutes under normal driving conditions. While its effect is similar to that of an aftermarket nitrous oxide system, the SuperCooler is completely self-contained, environmentally friendly and regenerative.
Cry02
this sounds alot like the cry02 system. only the cryo system blast's the intercooler with CO2 to cool it down. now this system isnt regeneritive but it disipates more heat from the intercooler. can this be adapted to our car?
that might be bad. think, using a/c for 2 minutes while it lasts 30 seconds. so if ur in a race ur good for a little bit, then u have a 20% lost of power for 2 minutes while ur a/c kicks without ur control...iduno
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
