Swapping pulleys question
just a question, i have a 2006 cobalt ss/sc, i already have 60# injectors with a zzp 1.0 pcm tuned for the injectors and my ls4 throttle body, I'm going from a 3.1 pulley to a 2.7, would i need to get a tune, or would i be good since I'm already tunes for they injectors.
I would say it's gonna be a stretch; you'll be pulling in more air than the ECU is programmed to push fuel for. I'm not a pro, but i would think it would run too lean jumping that much of a pulley size.
In other words, I'm hoping my opinion/bump helps you get the answer you're looking for
Don't be a cheap ricer; get the tune.
IF you don't have a way to monitor AFR right now, i'd look at grabbing an ELM327 OBD2 bluetooth dongle; you can sync to your (Android) phone, and get just about any sensor/data related information from your car you want through a few different apps, TORQUE being the best. that way you can monitor everything safely until and after it's tuned.
Decepticon06ss/sc
Oct 15, 2015 09:36 PM
breds2k
Oct 14, 2015 11:56 AM
