these should work!!!
Old Jan 20, 2007 | 08:53 PM
mattyfinch's Avatar
Weapon r has a cel eliminator that in theory should work with our cars.
http://www.weapon-r.com/cgi-bin/test...&ppinc=search2
Also this hasnt been talked about in a while, its the weapon r race header, it says redline, but the fitment i think would be the same for the cobalt.... **** it looks sick!!!
Old Jan 20, 2007 | 08:58 PM
Stilgar's Avatar
Every car I have owned, Weapon has shitty quality. Every car, fitment.
Old Jan 20, 2007 | 09:01 PM
mattyfinch's Avatar
you make no sense but ok
i know a few guys that had it and loved it.
Old Jan 20, 2007 | 09:07 PM
Stilgar's Avatar
Kinda tipsy, weapon r quality is ****. They have really bad fitment problems.
Old Jan 20, 2007 | 09:08 PM
sushidog's Avatar
I just ordered this cel eliminator for the p0420. http://cgi.ebay.com/ebaymotors/CHECK...67820810QQrdZ1
It's the cheapest out there. I'll keep you guys updated on the results.
Old Sep 3, 2007 | 09:37 AM
lil_kano's Avatar
I know this is an old thread, but any updates? I heard they don't have the fitment issues any more. Does the CEL eliminator work?
Old Sep 3, 2007 | 11:34 AM
FryLoch's Avatar
I hate weapon r, I will never buy anything from them again. I bought a weapon r TD and I hated it!!! Their quality is ****!
Old Sep 6, 2007 | 09:41 PM
lil_kano's Avatar
even though i do appreciate your input on the quality of thier work it still didn't answer the question of wether it works or not....lol. plus thier TD and Header are 2 diff products. now i know not to buy thier TD.
Old Sep 7, 2007 | 10:32 AM
LopsidedJester's Avatar
i just installed mine on my 05 Cobalt SS S/C, but i'm afraid to say it does have some slight fitment issues. First, it was hard as **** to get in, i had to jack up my car, unbolt my steering rack and move it, take off the rear trans mount, and then remove my front sway bar in order to get it up against the engine. After fitting it behind the engine, i realized the holes were cut a little wrong and it wouldn't fit, so i had to dremel out the holes for it to even mate with the manifold studs. After that I also found out that where they MIG welded the header on primary 1 and 4, the welds were so large on the outside as to restrict the nut from screwing down on the stud, thus, I had to dremel some more
And for as the quality, i spent a couple hours dremelling down primary welds (mainly on primary 1 and 4, inside and outside) and smoothing out the 4 into 2 transition. I also added a 3" to 2.5" reducer and 3" flange to the end so there would be a better transition to my catback.
After I installed the header, primary number 1 clears the engine by less than a millimeter, and when it goes from 4 into 2 it starts to rub against the bottom of the car, pushing on the heat shield.
Also, as for the MIL eliminator that they give you, it fits, and seems to work for a bit, BUT i am still frequently getting a CEL of p0140 which has to do with the HO2S Heater Signal. This means i don't think its a great fix, but is ok if you like clearing codes once in a while.
On the plus side, i can peel out into second gear as with my shorty header and stock downpipe i was unable. Also, my torque is more evenly distributed throughout my gears causing less peaky power and more low end get go to better compliment my 3" catback.
Old Sep 8, 2007 | 01:46 AM
lil_kano's Avatar
sweet info. thats the kinda stuff i realy would expect to hear. +rep. i think i'm set on getting this LT. thanks.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
