For Those With GM Stage II
I am sure it has been stated or a thread as been started but its early and I cant seem to find it so please comments only and no flaming, yesterday I got the stage II kit installed, I know how to drive the car, so my buddy who has an srt4 wanted to run me so I did, however when going WOT shifting into 2 and 3rd the clutch is slipping, does anyone else have this problem or is it that I need to work on my driver mod? Also when we stated I did not dump the clutch I rolled into it. Before the kit the clutch never slipped other maybe once shifting into second, and keep in mind I dont get one the throttle very often.
I knew it probably was. it was just a curiousity if its a majority overall were having the problem thats all. Thanks for the input, not mention i'm at work so i kind of limited my search time lol
Originally Posted by CTCOBALTSSS
If you are looking to do the spec 2+ and fidanza flywheel just do that. You'll be good to go.
Originally Posted by blown06
here is a stupid question lol what do you recommend for the clust master cylinder? for the clutch itself i am looking to do the spec 2+ and fidanza flywheel.
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/exedy-clutch-26554/
I must be lucky cause my clutch has never slipped, and i don't baby the car either, but it does sound like it could be a recall cause my dealer call me last week to see if i had any problems with the clutch sliping
Originally Posted by p7x
F! everything thats out right now. The Exedy hyperclutch comes out in sept or a lil later and will own all.
https://www.cobaltss.net/forums/showthread.php?t=26554
I'm in the same situation as the orginal poster. No clutch problems stock, but after stage 2, my clutch is garbage. It only seems to be a problem in 1st and 2nd gear though.
There was a guy on here (i think his name was badmunky or something like that ) who actually did alot of research into perhaps getting GM to replace it, but ended up getting screwed over and having his warranty threatened.
I've heard nothing but good things about the spec clutches, so i'm strongly considering getting a stage 2+ or stage 3 spec clutch.
Until then, i'll just have to delay the 1st-2nd shift.
Exedy cluch > all
Save your money and consider that if your willing to put up with a slightly harsh clutch that WONT slip. I've got a stage 2 and I've never seen slip. Even on a borrowed set of slicks. I believe the replacement master cylinder of choice currently is a adjustable corvette Z06 setup. Which is what I also did. After the install your going to have to leanr how to drive the car all over again though. Lighter flywheel + HD clutch = stalling when your trying to putt around town.
Originally Posted by SpecialK
Exedy cluch > all
For conversion sake take K / 1.625 to the miles for you YANKEES. LOL I say this with affection. so dont flame for being racist against USA.
Racist!!!
I have had a little trouble with mine. after some good beatings on it, it acts up, and i take it easy for a few weeks. then no problems. They still suck and should have used good ones in the first place.
Originally Posted by R33P3R007
Racist!!!
Racist!!!
HMMMM.... are we talking about the same thing? or are you talking about your girl or boy friend?
SORRY!!..... couldnt resist that line.
