for those with the ottp stg1 kit
when it asks (Rev Limiter RPM: 7000 7200 7400) is it safe to take the motor past 7k under stock internals or would it be better to do 7k
also what exactly is torque management and what does it do( Remove Torque Management: Yes No) and what did u guys select
also why do they ask you if the car has a cat still(Catalytic Converter On Vehicle:Yes No ) is it 4 the tune
another question are the pcm that ottp sends u with the sage kits anygood.....how are there tunes when first recieveing the ottp stage kit.did u have to get retuned
7200 is fine for most of you guys!
You want torque management removed, but you'll have to change your driving style as all the motor and tranny safeguards will be removed.
Yes it's for the tune, because if you are catless they need to remove the 02 sensor code from your car so you don't have CEL's.
And yes Josh and Sean at OTTP are very good tuners, the only vendor I would let within 10 feet of an LSJ with a cable!
Sep 28, 2015 12:51 PM
