Those who have a 2.8" pulley
Old Apr 25, 2007 | 10:03 PM
Boost Fr33k's Avatar
Just wondering for those who have a 2.8" pulley. what are your current mods, dynos, and any issues.
Old Apr 25, 2007 | 10:44 PM
SSdan's Avatar
2.8", Stage 2 tune + injectors, CAI, catback exhaust. I used to get a lean backfire around 5800rpm's until i changed out my plugs. Now it's all good.
BTW, i dyno'd 244whp/220tq.
Old Apr 26, 2007 | 11:20 AM
Area47's Avatar
Rent me! per hour
42.5 injectors
2.8
k&n cai
main issue is the timing. stage 2 runs too much timing to run the 2.8 safely. drop the timing down 10 degrees on advance and you're good. run a bit more fuel as well to se safe.
numbers in sig on 9-12.5 degrees of timing. im now at 17.5 degrees with no knock.
Old Apr 26, 2007 | 02:41 PM
JapEatr's Avatar
South Central *********
mods in sig, have boost limited in first to help with traction
Old Apr 26, 2007 | 02:46 PM
Originally Posted by Area47
42.5 injectors
2.8
k&n cai
what was your afr at OT?
Old Apr 26, 2007 | 02:47 PM
PlaysWitCars's Avatar
Former Cobalt Owner
2.8" with 60lbers, front mount HE, XTC Header,2.5" XTC Downpipe w/cat, magnaflow catback, XTC intake w/ air box mod, TAG Tuned
No issues other than a slight idle issue when i come to a stop. Mainly in colder weather.
thats actually pretty smart, you have a boost controller? how much psi?
Old Apr 26, 2007 | 02:51 PM
Rage915's Avatar
gmp stg 2 with 2.8 pulley, full hahn header back exhaust, injen CAI, NGK plugs, and CA heat exchanger. with this setup i dynoed at 256WHP and 231TQ
Old Apr 26, 2007 | 02:52 PM
jester's Avatar
you can control boost in hptuners.
I have a 2.8 60's intake and exhaust and have no problems, im usually around 12
Old Apr 26, 2007 | 02:57 PM
Coballsnation's Avatar
42.5 injectors
2.8
k&n cai
there is no way your running 263whp on 9 degrees of timing haha.
gg
stage 2 timing on the 2.8 is fine on 93 octane with 2 step colder plugs. very simple.
Old Apr 26, 2007 | 03:02 PM
yah i figured but i dont wana tune myself, but i have thought of buying a controller.
QuikSilverSS's Avatar
I have GM Stage 2, AEM CAI, ZEX Plugs, Pulley Boys 2.8...94 Octane............dyno'd 257whp 233wtq. Dyno sheet is in my pics
Old Apr 26, 2007 | 03:21 PM
Area47's Avatar
Rent me! per hour
gg
i will post the log tonight.
it's not pretty at all.
please keep in mind, not all of us have access to 93 octane. my car is tuned on 91.
a/f ratio at the tip is 11.0. a/f at the tip without tuning the fuel side was 11.2 on the stage 2 gm map. this is also after the cat. so add roughly .5 to that.
also, running a step colder plugs. and boost limited in first to 10 psi
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
