Throw out bearing problem I think
Old Oct 28, 2011 | 06:04 PM
Blown07SS's Avatar
I had installed a clutch last Friday and everything is new but I'm pretty sure the noise I hear is the throw out bearing (squeaking constantly) not loud but enough to anoy anyone without a exhaust. Is this a bad bearing? It has been in the shop for a while but I don't plan on driving it until I figure this out before it leads to other problems.
Old Oct 28, 2011 | 06:18 PM
terry11's Avatar
Yeah your smart not driving it. What clutch did you go with? Most aftermarket clutches for our cars overextend the tob due to the finger height being insufficient causing the seal to blow. ZZP is the only clutch that has addressed this issue.
I drove mine on a bad tob and it wiped out my stage 4 and broke something in the trans. Yay
Mine only had 10k on it when it went. Went in and put the upgraded tob in got it all back together and it still wouldn't shift. Which is when I realized the trans was broke and it still squeeled like a bit**. (clutch)
FML
Old Oct 28, 2011 | 07:53 PM
Blown07SS's Avatar
Damn I got exedy stage 1 and took out my stage 3 due to it causing to many problems for my actuator and firewall bs. Thanks for the info and everything is exedy even the throw out Bering. Hmmm gotta order a new one I guess but what's a good upgraded throw out Bering?
But I tested it out in the lot and it drives just don't want to push it unroll problem resolved.
Old Oct 28, 2011 | 09:07 PM
mrbelvedere's Avatar
get a gmpp clutch kit
Old Oct 30, 2011 | 02:08 PM
terry11's Avatar
zzp has an upgraded tob.
Old Oct 30, 2011 | 02:39 PM
Sharkey's Avatar
the upgrade throw out bearing is just the stock lnf unit. if you dont want to order one you can get it at your local dealer.
Old Oct 30, 2011 | 02:41 PM
Blown07SS's Avatar
Sweet I will get one from my dealer or is zzp cheaper?
06MetallicBalt
Jul 20, 2025 08:47 PM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
OPCrer
Sep 27, 2015 08:11 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
