Throw out bearing problem I think
I had installed a clutch last Friday and everything is new but I'm pretty sure the noise I hear is the throw out bearing (squeaking constantly) not loud but enough to anoy anyone without a exhaust. Is this a bad bearing? It has been in the shop for a while but I don't plan on driving it until I figure this out before it leads to other problems.
Yeah your smart not driving it. What clutch did you go with? Most aftermarket clutches for our cars overextend the tob due to the finger height being insufficient causing the seal to blow. ZZP is the only clutch that has addressed this issue.
I drove mine on a bad tob and it wiped out my stage 4 and broke something in the trans. Yay
Mine only had 10k on it when it went. Went in and put the upgraded tob in got it all back together and it still wouldn't shift. Which is when I realized the trans was broke and it still squeeled like a bit**. (clutch)
FML
FML
Damn I got exedy stage 1 and took out my stage 3 due to it causing to many problems for my actuator and firewall bs. Thanks for the info and everything is exedy even the throw out Bering. Hmmm gotta order a new one I guess but what's a good upgraded throw out Bering?
But I tested it out in the lot and it drives just don't want to push it unroll problem resolved.
DANRICKARD
Oct 1, 2015 12:08 AM
