ticking noise from under the car help
Old Nov 1, 2007 | 10:17 AM
sSsuPerChaRgEd07's Avatar
every time I first start the car up a loud ticking noise comes from under the car as I drive off it get louder then after driving 50 feet it stops. any ideas what it could be? techs can't even figure it out.
Old Nov 1, 2007 | 10:20 AM
DoubleLP's Avatar
Usually the only ticking noise is after you shut the car off. It comes from the catalytic converter. Where under the car is the ticking noise coming from? And does it only happen when it is cold or everytime that you start the car?
Old Nov 1, 2007 | 10:31 AM
Blk06SSTexMan's Avatar
you sure it's not a bomb?
Old Nov 1, 2007 | 10:33 AM
wdsoccer's Avatar
mine has a little "ticking" sound from under the car sometimes. mine cause my magnaflow catback. where it bolts together some air gets out and makes the ticking noise. i fixed it with exhaust tape stuff that i got at autozone
Old Nov 1, 2007 | 10:38 AM
rickyw's Avatar
if it does it from stop to driving off or when your in reverse turnning you need your axels relubbed or new axels
Old Nov 1, 2007 | 10:57 AM
it only happens when I first start the car when it warms up it stops. if it sits for a long time then I start it its louder. it sounds like its coming from under the car its not a metal clinging noise the tech thought it was the heat shield but it wasn't. its not a metal clinging noise its a loud tick and it gets faster as u accelerate in a rev or driving. its driving me crazy
my axels do make a noice a single click when I go in reverse that's it I was told that was normal. this is something different though the ticking is non stop til the car warmsup
Last edited by sSsuPerChaRgEd07; Nov 1, 2007 at 10:57 AM. Reason: Automerged Doublepost
Old Nov 1, 2007 | 11:03 AM
zrated89's Avatar
ive noticed that on my balt as well, i think it has something to do with the cold start mode. because after you drive it, it goes away. sounds to me like its in the valve train.
funny mines also an 07
Old Nov 1, 2007 | 11:31 AM
anyone else ever eperience this problem or have any ideaof what the problem can be? there is no performance loss or any driving problems its just a noise
Old Apr 17, 2008 | 02:27 PM
scampbell's Avatar
Ticking
My 07 SS SC has been making the same noise whenever it is has been sitting and I start up and start backing up or driving off i hear maybe ten or so ticks that are totally random they seem to happen under acceleration and when i let off the gas and the engine moves inside the motor mounts. Its really starting to **** me off did you ever figure out what it was?
Old Apr 17, 2008 | 02:33 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
JESUS... what a bunch of N00B's trying to answer this problem.
It is your STOCK cat-back. Plain and Simple. The stock cat-back CONSTANTLY ticks when it is warm. I had the same thing when I bought the car... and it went away when I installed my GMPP Performance Cat-Back.
Its not the cat... because I put on a brand new stock downpipe about 6 months ago... and the ticking didn't come back.
Old Apr 17, 2008 | 02:34 PM
Mike's Avatar
Maybe it's a very small exhaust leak that closes up after the pipes heat up and expand. Try checking your header/dp connection and your dp/catback connection.
Old Apr 17, 2008 | 02:35 PM
No... its not a leak... exhaust leaks don't tick... they kinda whistle when you push the gas in.
Its the metal from the stock Cat-Back.
[/thread]
Lock this bitch.
Old Apr 17, 2008 | 02:36 PM
Mike's Avatar
He said the sound goes away when it's warmed up.
Old Apr 17, 2008 | 02:38 PM
Its the stock Cat-Back. Do I need to put this into a rap song to a slick beat?
Order the GMPP Performance exhaust and install it... if the ticking doesn't go away, I'LL pay for the exhaust.
Old Apr 17, 2008 | 02:46 PM
pdub's Avatar
It's users with this sort of helpful tone that really contribute to the wellness of the css.net community. /sarcasm
Exhaust ticking occurs from expanding or contracting metal. This would happen by the exhaust metal or surrounding metals (such as a heat shield) heating up or cooling down. Just judging by your post and replies, I'd say have the dealer double-check your whole exhaust to rule that out and also get the axles checked. If your vehicle is under warranty, and they say it is not the exhaust, then they must find what the issue is so that your vehicle is safe!
Old Apr 17, 2008 | 02:51 PM
Mike's Avatar
Not trying to argue, but you said the stock catback ticks constantly when the car is warm, and he says the ticking goes away after the car has warmed up, so that makes it sound like two different things to me.
I have had small exhaust leaks in the past that made a "tick-like" sound to me, though everyone's interpretation of what sounds like a "tick" is different.
I guess the point is, since no one else has personally heard the sound in question, we're all really just guessing.
Old Apr 17, 2008 | 04:59 PM
Silv3r's Avatar
My car ticks a bit too when it's first started, after it hits 35-40 celsius it goes away. I never worried about it, my last 2 cars have done the same. I just figure its the block or exhaust expanding as it's being heating rapidly.
Old Apr 17, 2008 | 05:09 PM
scampbell's Avatar
I have had the GMPP cat back and Manifold installed on my car for almost 8 months now and this problem just started recently out of the blue it seems like. I dont think it is anything to do with exhaust this sounds more like an axle or something around that area. It only lasts for maybe 50 feet after the car has been sitting for at least 15 minutes then it just goes away. Performance isnt affected at all its just really bad sounding and it seems to be getting worse since I installed my stage 2 a couple days ago.
brickloaf
Sep 25, 2015 09:10 PM
DevZX
Sep 16, 2015 06:19 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Infamous SC/SS
Sep 4, 2015 05:33 PM
soundjunky
Sep 3, 2015 01:18 PM
