Timing Help!
Old Jun 23, 2011 | 10:06 PM
turdsandwich SS's Avatar
Timing Help!
I finally got my car all back together and now i'm trying to get it in time and it's not working. I cant get the crank timing mark at 5 o'clock and the cams at 2 and 10 by using the marks on the chain. The arrows on the cams are at about 11 and 2ish when the crank is at 5 and if I move the exhaust cam to 10 then it isnt on the mark on the chain anymore. I was wondering if you have to use those marks or if theres an easier way to do this. Any help would be great.
thanks
Old Jun 24, 2011 | 03:16 AM
InfraRedline's Avatar
Are you putting a wrench on the exhaust cam and persuading it into the sweet spot while a friend slides the exhaust cam gear on? Thats the easiest way to do it.
Old Jun 24, 2011 | 06:52 AM
mrbelvedere's Avatar
read the 300hp build book it will show you whay to do
Old Jun 24, 2011 | 07:21 AM
Axelthered05's Avatar
I would Also Like to know the answer to this question subed for answers
Old Jun 24, 2011 | 11:19 AM
hungryhip-ccp's Avatar
This, and it won't quite be at 10 until you put the tensioner in.
Old Jun 24, 2011 | 11:32 AM
scroll down read chapter 6
http://www.******************/forums...ooks-pdfs.html
replace the stars with r e d l i n e f o r u m s
Old Jun 24, 2011 | 02:21 PM
Yep the build book is what I followed when I did mine
Old Jun 25, 2011 | 09:32 AM
putting the tensioner i has nothing to do with the timing gear position
Old Jun 25, 2011 | 12:10 PM
I have that 300hp book but I cant find it. I talked to a guy at GM and he told me just to get it at TDC and then just match the marks on the cams with the marks on the chain and I'll b fine. Does that sound right? Also, when I went to put my cam sensor back in it isn't exactly straight up when its at TDC so I was wondering if that would matter. thanks
Old Jun 25, 2011 | 12:12 PM
That is how I did it. I have it together right now I'm just not sure if its right.
Old Jun 25, 2011 | 08:37 PM
The links and triangles should line straight up, as well as the mark and colored link at the 5 o'clock position. Triangles should be in the direct center of each link.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
