'Timing' what is it?
Old Sep 13, 2005 | 05:57 PM
Maverick's Avatar
May sound like a stupid question but what is 'timing'?
For instance when someone says, "...the car is pulling timing."
or
"...add some more timing."
Thanks.
Old Sep 13, 2005 | 06:30 PM
codyss's Avatar
Timing has to do with ignition, and is the point at which the spark plug is fired in relation to piston position.
Old Sep 13, 2005 | 08:10 PM
Spanky's Avatar
there are a few timing points in engines now adays but the most common that is being refered to is ignition timing. when the pistion is at the top dead center (TDC) the spark will fire and this is the timing of the ignition. there is a lot more to it but i dont want to get toooo technical bc this can easily turn into a "i know more about cars than you thread" so i will leave it at this.
Old Sep 13, 2005 | 09:24 PM
Halfcent's Avatar
I'm old school
Actually, too late. Spark plugs fire before TDC, not at TDC.
Ignition timing is what they are referring to. However, Cam shaft timing is also adjustable.
Old Sep 14, 2005 | 01:26 AM
Nocturn's Avatar
IT is also when the camshafts push in the valves in relationship to the piston/crankshaft. The two shafts have to be coordinated so that the valves are opening at the precise moment they are meant to, this is done by tying them togethor using a timming belt (on DOHC). There is also the ignition timming, which as said times the spark plug with the valves and etc to fire the spark at the right moment so that it acheives better combustion.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
