timming for a 2.6 ring
Old Jan 8, 2009 | 05:56 PM
blacksssc06's Avatar
whats the max timming you would run with a 2.6? im at 30 with no knock.
Old Jan 8, 2009 | 06:07 PM
SSdan's Avatar
Anything over 26* doesnt make extra power fyi.
Old Jan 8, 2009 | 06:34 PM
coopn8r's Avatar
I'm at 24 degrees conservative street tune with no wideband to see so we didn't try going anymore
Old Jan 8, 2009 | 06:41 PM
BoostedYards86's Avatar
*on most cars power is not gained over 25degrees* if you have dyno results that prove other wise postem and keep on going on lol
Area47's Avatar
Rent me! per hour
if you're running 30. your car is too rich.
Old Jan 8, 2009 | 06:43 PM
johnladow07's Avatar
yikes...im running between 11.2-11.7 WOT and 21.5 degrees of timing. my tuner and I like being safe though
Old Jan 8, 2009 | 06:52 PM
Area47's Avatar
Rent me! per hour
i do.
Old Jan 8, 2009 | 06:55 PM
Steven Flit's Avatar
Originally Posted by Area47
i do.
Is that at 100% TP? Or is it 50-75% TP range on the timing table.
I thought you mentioned something about anything above 25* improved trq, not hp a while back.
Old Jan 8, 2009 | 07:01 PM
Area47's Avatar
Rent me! per hour
100%. i run well over 45 degree's at part throttle below .52 g/cyl.
Old Jan 8, 2009 | 07:22 PM
HOT CARLS SS's Avatar
Area at 45 degrees down low isn't that going too pop the motor depending on boost and compression?? How much timing do you run from 2000-5000 with or without meth?? If you wanted a conservative tune with meth and making good hp how much timing would you run with a 2.6 at 7200rpms....
Old Jan 8, 2009 | 07:28 PM
Area i know you do lol. u have like every dyno ever made. jk but honestly that was just for the op.
Old Jan 8, 2009 | 07:42 PM
Enjoying the MPG w/ your timing being like that below .52 g/cyl?
I didn't think you could take it that high... im in the mid 30s below for the majority of the part-throttle under .52 g/cyl, except in the cruising zone of 2048-3584 rpm at 0.08-0.12 g/cyl tops is 41*.
Old Jan 8, 2009 | 07:57 PM
Area47's Avatar
Rent me! per hour
summer gas i run in the mid 20's under full throttle. part throttle doesn't change due to gas mileage. i like my 30+ in the city
i have the car detuned for winter crap gas. around 21 degree's. give or take a few. every car will be different in what timing it wants, but the general rule of it is still the same. 99% of the end users are not going to run lean enough to be able to take full effect of 27+ degree's of timing anyways.
Old Jan 8, 2009 | 08:02 PM
didn't know the gas varied from seasons... Then again we don't rly have seasons out here in SOCAL Los Angeles.
Old Jan 8, 2009 | 08:13 PM
Area47's Avatar
Rent me! per hour
yepo. which is why my car is down 30whp right now. fuel differences for one, and not being able to run the additional timing. 1 degree of timing in my car is equal to 5 whp.
Old Jan 8, 2009 | 08:21 PM
so i should just turn it down to 27 and stop
Old Jan 8, 2009 | 08:23 PM
where are you making 27* of timing on the timing table?
happen to have a screen shot?
Old Jan 8, 2009 | 08:29 PM
Area47's Avatar
Rent me! per hour
still too much with the afr you want to run
Old Jan 8, 2009 | 08:39 PM
Area: How much timing did you run down low from 2000-5000rpms in the M62 with out meth?? And with Meth?
Old Jan 8, 2009 | 08:46 PM
Area47's Avatar
Rent me! per hour
ohhh i can't tell ya that one
Old Jan 8, 2009 | 09:11 PM
jeanbalt's Avatar
they want to know how long you dick is too !!
Old Jan 8, 2009 | 09:38 PM
Area47's Avatar
Rent me! per hour
not big enough. im a guy, but im modest
Old Jan 8, 2009 | 09:47 PM
jeanbalt's Avatar
GUY PICK UPS A LAMP RUBS IT
A GENIE POPS UP SAYS I WILL GRANT YOU A WISH
GUY SAYS I WANT MY DICK TO TOUCH THE GROUND
... SO HIS LEGS STARTED SHRINKING
there is always a catch
when someone "gives " you the info it's gonna cost you
Old Jan 8, 2009 | 09:48 PM
hahah very funny no....you don't have too be exact just approx....
Old Jan 8, 2009 | 09:50 PM
jeanbalt's Avatar
it's a judgment thing almost an art to figure
out what is better for each car but knowing the general theory for most
