Torq dampeners or poly mounts?
Old Mar 27, 2008 | 10:43 PM
SS/SC Crazer's Avatar
Ok, i have been reading the threads but im still confused, maybe im just stupid, idk, anyways, I plan on running a stage 5 kit which consists of a ported supercharger, 2.5" pulley, 60lb injectors, 2 step colder sparkplugs, duel pass end plate, and heat exchanger and poss meth with a cai and full exhaust. basically i am looking to get as much hp out of the car as i can while still driving on the street. however, should i get all 3 mounts ( engine and both trans ) with control arm bushings? or the ingalls torque dampener? or should i get both? will this stop wheel hop? i know that i will get alot of extra vibration and thats ok. I also don't plan on getting this kit till later this summer, if i put the mounts on my stock balt, will there be any hop or is this going over board, do they help the car launch any better? wow i had more questions than i thought.
Old Mar 27, 2008 | 10:48 PM
Red2.4SS's Avatar
Mounts for sure with what you are planning to do.
Old Mar 27, 2008 | 10:51 PM
XM15's Avatar
If you get the TTR engine mount, you don't need the torque damper. Personally I would go with all three mounts.
Old Mar 27, 2008 | 10:52 PM
WhiteSSBalt's Avatar
Not a Sebring
I have the Ingalls, but i've yet to install my Prothane tranny mount inserts.
Old Mar 27, 2008 | 11:02 PM
flathead0's Avatar
im going with TTR engine Mount, and tranny mounts, BTW should make this a pole
Old Mar 27, 2008 | 11:39 PM
Wuts the difference between TTR's mound and CA's mount? other than color
Old Mar 28, 2008 | 12:13 AM
Red2.4SS's Avatar
You can customize the TTR motor mount.
They are both polyurethane.
Just get the motor mount and tranny mounts. Much more effective than the damper.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
n20saturn
Sep 30, 2015 12:26 AM
Sep 27, 2015 08:53 PM
