Traction Control is m.i.a ???
Old Jan 7, 2013 | 08:56 PM
Ss27gogeta's Avatar
dose the windows and radio still work
Old Jan 7, 2013 | 08:57 PM
Cruzzer38's Avatar
yeah windows and radio work fine
Old Jan 16, 2013 | 12:36 AM
Cruzzer38's Avatar
K guys so I have the car and here's what I'm dealing with...
There were no air pump fuses (supposed to be 2 in the box under the hood) and that's probably why it threw a code for running rich, I'm assuming the pump might be faulty if the fuses were taken out. I'm putting in fuses in the afternoon, not sure how I'm supposed to tell if its working? (Pretty sure dealer erased the code but I had a buddy use an obd scanner, nd it still tells the scanner smthns up)
There are 2 rattles, when the car idles it seems to be coming from the head, I was told it could be a lifter bc it goes away when I rev the car, but I had bad lifters in an intrigue and that was louder and sounded more like crickets, 2nd rattle happens when I try to turn the air on, it can only be heard inside the car and my buddy's dad thinks its the compressor or fan.
There wasn't a fuse for the pwr locks so I put one in, they still don't work, but the car locks when I start to drive and unlocks when I turn it off. I'm really just thinking of taking it into a dealer if i cant find out the exact roots of the problem and having them go over the car completely. It's 82$ an hour though, so I wanna see if anybody has come across these issues. There's a powertrain warranty on the car, so if anything major comes up I should be ok.
Old Jan 16, 2013 | 06:57 PM
mrbelvedere's Avatar
the car dosent have an air pump check your emissions fuse
GDS
Old Jan 17, 2013 | 10:30 AM
Cruzzer38's Avatar
Yeah I found that's for Cali cars. Thanks, I'm checking everything out tmrw after classes so ill keep that in mind
Old Jan 17, 2013 | 03:29 PM
cali cars don't have a air pump on them either
GDS
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Coballin13
Sep 25, 2015 08:43 AM
