tried to do a lil top speed run and...
it was a closed circuit where i did the top speeds as well
i went up to 147 when i was stock
got inectors,maf-t,2.7,intake,and downpipe and the car made it to 140 and it wouldnt go any faster
i let off the throttle and i went to give it gas again and the car felt like it had no ***** whatsoever i then procedded to slow down and go down to second gear and i floored it and i then had almost little to no power, i continued to slow down and decided to see what happens when i launched it.. lemme put it this way i had NO JUMPING OR SPINNING OF MY TIRES
i let the car sit for a day and then i drove it hard and it felt fine again but every time i go fast then let off, the car feels like **** for almost a day
and i put fuel injector cleaner and drygas in the car
WTF is wrong?
i personally think i have a bad fuel pump but i need help cause it doesnt make any sense
WTF is wrong?
you probably need more tuning or a bigger pulley. Ineffiency is whats causing your car to run like that. Either the car is not getting enough fuel or the blower is causing a decrease in power from being overspun. Put on a 2.9 or 3.0 if you can and do the same run just to see if you can go faster.
all you gotta do it is turn the car off and when u turn it back on itll be fine. I had that happen to me to when I first got my intense kit, I would always win the first race, go up to 130 and then lose all of them and the car would feel sluggish and it wouldnt advance. If you had a wideband you would see this happens because the car richens out too much. The pcm senses the car running at really hot temperatures, only reached when you go over 120 and signals the injectors to throw a lot more fuel. messing up ur tune richening your car and becoming really really slow.
get a wide band o2 , fuel pressure gauge , and a gauge or laptop that will allow you to moniter the knock retard , and iat temps , and timing
the maf thing you have prob isnt doing the job you need it to , and needs to be changed , but with out the other info from above said readings your not gonna know which way to go with tuning
The problem is most likely torque managment and things like catalytic overheat protection which pulls timing if the cat gets to hot. Little crap like that is all over the PCM code. Get an aftermarket PCM such as the one we sell.
