trouble getting into gear
Old Apr 3, 2006 | 07:06 PM
phxSS's Avatar
About the last two weeks, occasionally, my car has been hard to engage first, or shift into second. It happened today also; I was trying to get into first gear to get onto the freeway, and i had to pump the clutch a bunch of times to engage it; and another time I launched kinda hard, but not racing hard, and I couldn't shift into second gear for a second. Does my clucth have to be adjusted, or is it auto adjust? My car has 14.5k miles, and all this started recently.
Old Apr 4, 2006 | 12:06 AM
Blown 4-banger's Avatar
Wow! I just got an '06 SS S/C and the same thing happened to me, I was at a red light in neutral, and when the light turned green I couldn't get it into first, I ended up having to start in second.
Old Apr 4, 2006 | 02:18 AM
Bika's Avatar
Fail Less.
im having a similar problem, only with 5th gear. releasing and pressing the clutch usually does the trick though. i only have 1.900 miles on my car tho.
Old Apr 4, 2006 | 05:56 AM
cavy9psi's Avatar
a good amount of manual transmission problems are external start with the linkage and try the clutch fluid maybe for some wierd reason its overfilled or underfilled, dont think straight to needing a clutch adjustment...my girlfriends brand new SRT-4 is stupid like that when its cold out and the car isnt at normal temp yet then works fine once you drive it for about 10 mins...its gettin warm out now and doesnt do that anymore...what i did was in the driveway before i left id pump the clutch (in neutral) like 5-10 times then hold the clutch in and run it through the gears and on cold days it limited my problem....the gearbox isnt the best.....
Old Apr 4, 2006 | 08:31 AM
BLKSS's Avatar
It happens alot on startup. Just push the clutch back in and it should go.
Old Apr 4, 2006 | 01:27 PM
cavy9psi's Avatar
so before the car is running? is it cold out?
Old Apr 4, 2006 | 07:30 PM
well when it happened to me it tried 3 or 4 times, going into neutral releasing the clutch then trying again, cars were honking so i just started in 2nd. It hasn't happened since, mabey because my car only had like 70 miles on it.
Old Apr 4, 2006 | 08:50 PM
phxSS's Avatar
Yea, people were getting impatient behind me too. Hmmm. Hasn't happened again lately.
Old Apr 5, 2006 | 06:02 AM
cavy9psi's Avatar
dont forget clutch have break in periods especially if you bought the car with no more then 3-4 miles on it you prolly break it in till about 100-200 miles i didnt beat on my girl friends SRT when she got it with 2 miles until it was at 400..didnt even see boost, now.....................................lol it goes through hell..that coulda been ur problems
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
matthewwalsh1994@gma
Sep 10, 2015 10:48 AM
