Trying to get the cobalt to do atleast 11.5 in the quater mile by june?
Old 04-10-2011, 08:52 PM
valentino0214's Avatar
I'm unsure what option I wanna go with to get 11.5 in the quater... Without getting a new car
some options I had in mind:
Harrop S/C with head work 78lb valves
Turbo Swap
Twin charge
I need some ideas....
Old 04-10-2011, 08:57 PM
Zero6LS's Avatar
i highly doubt that ur gonna get into the 11s on a tvs. build ur block, get a precision turbo (5557) and u should be good
Old 04-10-2011, 08:58 PM
jmesl8er's Avatar
push it with a supra???
Old 04-10-2011, 08:59 PM
Just do head work?? and turbo swap it?
I was thinking pull it with a jet truck...
Old 04-10-2011, 09:02 PM
Perfect.disguise's Avatar
He said run mid 11's not trap 140mph.
Old 04-10-2011, 09:04 PM
kxrida2000's Avatar
ur gonna have to spend a good amount is wat ill contribute...and turbo swap
Old 04-10-2011, 09:05 PM
I got the money for it... I just need to get 11.5... What do you think i would need to do?
Old 04-10-2011, 09:06 PM
Zero6LS's Avatar
hey 140 in a balt tho would be nice too lol
Old 04-10-2011, 09:09 PM
kxrida2000's Avatar
depends on how "safe" u wanna be. I built my block completely and run a zzp turbo kit and should run 11.5 on slicks with no problem. I should be around 450hp and could crank it up higher if i need too. My weak spot is my transmission cause im a 2.2 cobalt. Ur an ss so zzp will be releasing a tranny in may to support some power. So id say zzp tranny, axles, slicks, zzp turbo kit or piece ur own together, and build your block if u want to be safe and not have a ticking time bomb
Old 04-10-2011, 11:51 PM
mrbelvedere's Avatar
you can do it on a tvs and a set of cams exhaust and so on people are so quick to run from what they dont have experience with
Old 04-10-2011, 11:58 PM
kxrida2000's Avatar
agreed but u have a lot more room to grow with turbo if u want
Old 04-11-2011, 12:03 AM
Who has run in the 11's on a TVS?
Old 04-11-2011, 12:13 AM
270 hp is enough for 12s with stickies if you can drive 350 with a tvs and stickies is enough to run in the 11s with stickies and someone who has taken the time to learn how to drive their car
Old 04-11-2011, 12:19 AM
All I asked is who has ran 11's with a TVS.
Old 04-11-2011, 12:23 AM
EXsoccer1921's Avatar
do your suspension/wheels&tires/clutch/drivetrain first. then see what kind of power your need...
Old 04-11-2011, 04:10 PM
BlueStang's Avatar
Have a F 14 pull it
Old 04-11-2011, 04:12 PM
Originally Posted by Omega1x
My plan is 400 WHP while still using the M62. I know it's a long shot, but I want to see if it is possible.
ZZP already dd it on the LSJ.
Omega1x's Avatar
I honestly would try to stay TVS. I'm not saying that cuz it's for huge power, but it would be awesome to see a still S/C Balt do an 11 on the quarter. It will take work. I'm talking bore your engine, head work, port the head and blower, cams, nice tune, etc. My plan is similar to yours, but a horsepower goal and I'm not finishing this summer haha. My plan is 400 WHP while still using the M62. I know it's a long shot, but I want to see if it is possible.
Old 04-11-2011, 06:30 PM
blackcobalt1986's Avatar
Build the motor and either tvs or turbo and spary the rest of the way if u have to. IMO
Old 04-11-2011, 06:36 PM
i shall quote myself. i bet it won't be as much as you think you need at this point in time
Old 04-11-2011, 06:41 PM
awshopskater14's Avatar
Exactly. Best thing I did was tires and mounts. With all that power you need to be able to put it to the ground
Old 04-11-2011, 10:31 PM
alleycat58's Avatar
11s are definitely doable with the TVS. Hell, add a ported head and some cams on stickies and you should be able to get there without a problem, you just have to make sure you have stage 2 driver mod.
Old 04-11-2011, 10:44 PM
Then get at it people.
Old 04-11-2011, 10:46 PM
PrincessTurbo's Avatar
bwahaha
Old 04-11-2011, 11:19 PM
blewis13's Avatar
If you do TVS, they said there's nothing to be gained from porting. (IIRC) And yeah I know a guy said it already but just check out ZZP's website they made 400 whp on an M62.
Quick Reply: Trying to get the cobalt to do atleast 11.5 in the quater mile by june?
